Old 01-17-2011, 02:01 AM   #1
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default Dana 60 Gear Lube ??
How little can you get away with a Dana 60? Thanks
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 01-17-2011, 09:18 AM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 875 Times in 236 Posts
Default Re: Dana 60 Gear Lube ??
Ed, anything less than 3 1/2 pints and I had front pinion bearing spalling.
slowed down and leaked everywhere with more than 2 1/2 quarts.
Old 01-17-2011, 09:19 AM   #3
Dragsinger
Liked 99 Times in 60 Posts
Ed, I think 1.5 quarts would be fine. If it were mine I would run 80/90 GL5 conventional oil.
Larry Woodfin 471W
Old 01-17-2011, 09:44 AM   #4
Tom Goldman
I've found a substantial temperature reduction when running 75w140 GL5 synthetic oil over the conventional 80-90. .......Worth a couple of hundredths on my car. and wear was ok.
Different type of racing, but I have a few mud drag racers who swear that the best lube for wear and durability is the Moroso climbing gear lube.
Old 01-17-2011, 01:19 PM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,923 Times in 578 Posts
Ed
I run 2 qts of valvoline synthetic gear lube in my Dana. The gear life is forever although I run a powerglide.I run a 6.17 gear. I saw no advantage to running less lube. The dana did not hold up in my car with the stick. I would recommend a cover that incorporates a brace. I saw the pics that you posted about the damage to your dana. My experiance with a stick was similar with the side shims eaten up. Broken caps etc. I installed steel caps and studs on the spool bearings. I have Strange spool and axles.
Mike
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 01-17-2011, 03:30 PM   #6
Rod Greene
Liked 242 Times in 81 Posts
I use 1 qt of Lubricating Engineers lube. Sticky purple stuff. I have thousands of runs with a stick never a problem.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 01-17-2011, 04:32 PM   #7
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
In my Dana,I always used the factory recommended fill.I used conventional gear lube in the past but am switching to 75w140 synthetic with the new gear set,and I'll fill it to the factory specs.
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 01-17-2011, 09:40 PM   #8
Rory McNeil
Liked 1,103 Times in 301 Posts
I have a Dana 60 in my 10.0 ET,132MPH bracket car, with a Jerico 4 speed. I use the Redline "heavy shockproof" synthetic 90-140 gearoil (2 quarts), after after 9 years, the Richmond 4.88 Pro gears still look great. Of course, when you get into the really low gearing (5.86, 6.17 or so) gear life is much shorter, especially in a heavy car.
NHRA 6390 STK
M/S 85 Mustang
Old 01-17-2011, 10:11 PM   #9
Jeff Lee
Jeff Lee's Avatar
Same here but I ran 2 qts. Buy it at Lamb.
Jeff Lee 7494 D/S '70 AMX
