Old 10-13-2010, 10:30 AM   #1
KEVIN T
Default MSD rotor coming loose?
I have had problems lately with my distributor rotor coming loose. Also the adapter that the rotor attaches to. MSD Billet dist. in a BBC. Before I use loctite, which I don't believe should be necessary, has anyone expierenced this? I dont' know if a vibration/harmonics would cause this. Any ideas? Thanks,
Kevin Tiedemann
S/ST 145T
KEVIN T is offline   Reply With Quote
Old 10-13-2010, 11:24 AM   #2
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: MSD rotor coming loose?
Do the screws have conical washers on them? My old rotor had flat washers, new one came with funky looking conical washers which I believe is to eliminate loosening. Joe
Joe Buchanan SS/BX 3117
Old 10-15-2010, 09:05 AM   #3
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
I had to use loctite on mine. Just a drop.
Floyd Staggs 787 SST
Old 10-15-2010, 10:38 AM   #4
Kris Kurzweg
Conical washers and a drop of blue loctite....
Kris Kurzweg is offline   Reply With Quote
Old 10-15-2010, 02:24 PM   #5
danny waters sr
danny waters sr's Avatar
Thumbs up Re: MSD rotor coming loose?
x-2
Old 10-16-2010, 07:32 PM   #6
Ted Barnes
Ted Barnes's Avatar
I had this same problem on Labor Day...and I had the conical washers...now I use loctite AND the washers...we'll see if that holds...
It was strange...never had this problem before...
Ted Barnes 1511 HR
Ted Barnes is offline   Reply With Quote
Old 10-18-2010, 06:48 PM   #7
Tom Goldman
Tom Goldman's Avatar
Liked 882 Times in 236 Posts
Just because of this thread , I deceided to look at my rotor this weekend . ...Guess what,the rotor screws with the conical washers were tight, BUT the screw that holds the rotor adapter to the shaft was coming loose ,and it had been loctited [blue].....Got a dose of "red" this time. ..............Tom
Old 10-22-2010, 05:31 PM   #8
Buckster565
I have had this same problem on both of my distributors and solved it with blue loctite and have not had a problem in 4 years now.
Buckster565 is offline   Reply With Quote
Old 10-31-2010, 04:47 PM   #9
KEVIN T
Thanks for the advice, Loctite it is.
