Old 05-16-2010, 10:53 AM   #1
Redlight
Default 30x9 radial on a 12" rim?
Any problems putting a 30x9 radial on a 12" rim?
The tires have 5 passes on them so I would like to use them if possible.
I know the "rule of thumb" is + or - 1 inch of the tread width but I see some guys really stretching thier tires.
On the present chassis they are on a 10" rim but the offset for the new chassis needs to be different and have a set of 12" that will fit.
They would be screwed and glued as needed.
Will it work?
Redlight is offline   Reply With Quote
Old 05-16-2010, 11:04 AM   #2
treessavoy
Liked 4 Times in 4 Posts
Default Re: 30x9 radial on a 12" rim?
When I bought my Hoosier's the factory guys said to use an 8 to 10 inch wheel, no screws or glue. They did tell me to use rough sandpaper to roughen the areas around the bead to help seal.
I would call the tire makers before putting them on 12" rims.
JimR
Jim Rountree
Old 05-16-2010, 11:16 AM   #3
Steve Williams
Don't do it.
Steve Williams is offline   Reply With Quote
Old 05-16-2010, 11:29 AM   #4
Joe Martens
Joe Martens's Avatar
Liked 196 Times in 69 Posts
Thumbs down Re: 30x9 radial on a 12" rim?
I wouldn't do it.
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
Old 05-16-2010, 12:01 PM   #5
Bob Bender
Bob Bender's Avatar
Liked 459 Times in 90 Posts
10 is about all you go............
Bob Bender 144 O/SA
Old 05-16-2010, 02:14 PM   #6
Rory McNeil
Liked 1,104 Times in 302 Posts
Even if you did put the 9" slicks on a 12" rim, I`d bet getting the beads to seat against the rim flanges should be good for a few hours of "entertainment", assuming a tubeless installation.
NHRA 6390 STK
M/S 85 Mustang
Old 05-16-2010, 02:33 PM   #7
Jeff Lee
Jeff Lee's Avatar
Low Rider's do it all the time. And yea, they share freeway space and speeds with the rest of society all the time with these dangerous tires!
Jeff Lee 7494 D/S '70 AMX
Old 05-16-2010, 02:53 PM   #8
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
The radial sidewall is not designed to be "bowed" out like that. They will fit, but, the stiff sidewall will breakdown and quit hooking up right away. As far as being dangerous, I dont know.
Wade O
Old 05-16-2010, 03:23 PM   #9
Redlight
Ok, so anyone need a set of 9x30 radials with 5 runs on them?
Old 05-16-2010, 03:29 PM   #10
Kegracing
Yes, I need some. What type, what compound, and what roll out? Part number would answer all that I guess... Where located, and how much?
thanks,
Ken
Kegracing is offline   Reply With Quote
