Old 01-02-2010, 07:47 PM   #1
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Question deactivate a 2-step?
Ok I know this has been covered before BUT how do you guys deactivate the 2-step in high gear? I have a Turbo Action shifter rev pat. Thanks!
Old 01-02-2010, 08:10 PM   #2
Pat Cook
Default Re: deactivate a 2-step?
I use a micro switch from Radio Shack mounted to the shifter, when the lever is moved to high gear it opens the two step circuit so it doesn't kill the engine when your scrubbing of that critical .002 at the stripe.....
67 Ford Fairlane
F/SA
749
Pat Cook is offline   Reply With Quote
Old 01-02-2010, 08:57 PM   #3
danny waters sr
danny waters sr's Avatar
Thumbs up Re: deactivate a 2-step?
Same Here x-cept scrubbin .008 lol
Old 01-02-2010, 09:08 PM   #4
Jeff Teuton
Liked 325 Times in 50 Posts
Use a window switch that lets the 2 step operate between two assigned rpm ranges. Works great. Then in high gear above let's say 3500, it don't work.
Jeff Teuton 4022 STK
Old 01-03-2010, 01:01 PM   #5
my69396
Liked 46 Times in 20 Posts
How about a switch that only lets the power to the two-step in low gear?
my69396 is offline   Reply With Quote
Old 01-04-2010, 05:43 PM   #6
Dean3870
thats the way mine is set up. soon as i shift out of low gear the shifter comes off the micro switch, and disables the 2 step.
Dean3870 is offline   Reply With Quote
Old 01-05-2010, 07:53 AM   #7
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
i may be reading the wrong thing here, but my two step is activated off a starter push style button on the brake pedal not off the brake light switch. i have mounted it in a location on the brake pedal that is comfortable, but off to one side, that way when i hit the brake pedal my foot is just to the left of the switch and the two step is not activated.
Ian
Ian Hill is offline   Reply With Quote
Old 01-05-2010, 09:28 AM   #8
Bill Harris
Liked 26 Times in 13 Posts
Mine is set up the same as Ian's. Button is way to the left on the pedal. Mostly works except when I forget and don't keep my foot off the button on the top end. My car was originally a stick so my brake pedal is pretty narrow. An automatic pedal would have more room.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
