Looking for some input for first gear ratio. What would you recommend for my car. 2850lbs 383 small block, 29" tire with 4.56 gears. Shifting at 7200 running through the traps at 7000. Cars been 10.20's at 130 foot braking it with 4000 stall glide and a 1.94 gear set. 4 link car. Just loosen the converter to 4800. 8" ATI converter. Smaller, bigger looking for opinions from experience. I'm new to automatics and the gear set broke so I need another one. Thanks, Vinny
Liked 71 Times in 23 Posts
1.94 or 1.98 should be fine for that combo,loosening the converter will help ALOT 4000 was to tight.
Monte Howard 3209 STK, 3208 SS |
with a 383 and that light of a car just put the stock 1.76 gear set in the car and race if u do try to run the stock 1.82 u will have to pull in out after about 100 runs any more runs chanse of braking it
I'm going to trans brake it and I dont think the stock 1.76 gear will last plus I want to break into the 9's and I think it will need more than the 1.76 gear.
ow yes 1.76 will last even longer sens u running a small block 383 how much motor u got? I ran 1.76 with 406 for yrs low 10s and never broke in 3300 pound car tried 1.96 gear set and car did not like it to much first gear for the power
#7 | |
![]() Last edited by L79racer; 12-12-2009 at 01:58 PM. |
lost on 60 and et cant remember how much been so long my car head 4.56 gears and 32-14.5w stiff side wall lunch at 5500 on brake shift at 6500 and 6800 at finsh line
Anybody else want to add what gear they run and et?
I ran a 355" sbc in a 2860# chevy II with a 1.76 glide 5.67 rear gear. Car went a best of 1.33 60' @ 9.86 and consistent 9.90's @132mph at 8200 rpm in cool weather. I put a 2.03 low gear and 5.43 rear gear. 60' times dropped to 1.30-1.29 and ran basically the same E.T. and mph at 7900 rpm. You will have more rpm drop at gear change with the lower gear ratio. Car has a 8" 5800 convertor and a 15" x 33" 105" roll out. I leave with the trans brake at 4200 rpm. The car was more consistent with the 2.03 low gear due to being able to transfer the weight better, and a whole lot more fun to drive! The 2.03 broke after about 350 runs. I put the good old reliable 1.76 back in for now! Hope this helps.
4878 SS/GA 66CHEVY II |
