Liked 427 Times in 97 Posts
Would like some input on the Quick times bell housings vs Lakewood or McLeod?
Currently running a Lakewood, w/soft-lock & jerico, but hearing that more racers are switching to Quick Time bell housings. Would like to know more about the Fit, finish, access to clutch adjustments, removeable clutch access plates, room around the transmission, pricing, pro's & con's, ect? Information and opinions would be helpful Thanks Greg "Chicks dig Sticks" |
Liked 520 Times in 132 Posts
Had a lakewood switched to QT. QT is awesome. It is much lighter and ALOT easier to install. Just sent mine in to get the newly approved access window done. Sure will be nice adjusting the clutch with that.
Liked 13 Times in 4 Posts
Greg,
Once you see the QT bellhousing you'll never go back. Ours fit right up and gave us a ton more room on the Chevy II. It is SFI approved, lighter, fits better and has a new window for adjustments. Here is a picture of the new access panel that was just SFI approved for hte QT bellhousing. This is the prototype so it isn't painted but this is the only picture I know of online right now. http://www.carshopinc.com/popup_imag...fd695b44d5abe3 http://quicktime.carshopinc.com/prod...s_id/110327/RM
Joe Schaechter 3168 STK |
#4 | |
Jeff Lee 7494 D/S '70 AMX |
Greg,
A newer picture of the SFI QT bellhousing with the window has been posted on the internet now. Here is the link: http://www.carshopinc.com/popup_imag...2d25a3887bf003 http://quicktime.carshopinc.com/prod...s_id/110327/RM This looks like the production model with the SFI sticker.
Greg,
Here are a couple of pictures I took when we originally moved to the QT bellhousing (pre SFI windowed version). It makes the Lakewood bellhousing seem huge! From the top ![]() From the side ![]()
My Lakewood housing is 37 pounds including block plate and bolts. The quick Times can is 27 pounds including same parts. Bathroom scale but still a relative comparison.
Cam
Cam Chowen 6067 1994 Camaro C/S |
