Old 10-15-2008, 06:56 AM   #1
J Halsey Jr
Default h pipes
Is anybody running h pipes on stockers.If so any pros or cons about them.
J Halsey Jr is offline   Reply With Quote
Old 10-15-2008, 09:37 AM   #2
Liked 1,953 Times in 439 Posts
Default Re: h pipes
I've seen a couple of true X pipes on FAST cars, but no H pipes. They (X pipes) have to be properly configured for diameter, and length before and after the X, and they're pretty hard to fit up under the car.
Old 10-15-2008, 11:13 AM   #3
Chad Rhodes
Default Re: h pipes
and boy do they sound strange
Chad Rhodes 2113 I/SA
Old 10-15-2008, 01:24 PM   #4
Myron Piatek
Liked 138 Times in 51 Posts
Cool Re: h pipes
I've always heard that X-pipes can be faster than H-pipes. I put a TTI 3" X-pipe system with Dynomax Ultraflow mufflers ending at the rear end housing on my car. Every indication was that I picked up a bit, particularly after I removed 60lbs from elsewhere in the car to bring it back down to class minimum and did additional carb tuning.
Unfortunately I didn't do back-to-back tests. But I do keep extensive records of all my runs. I was sure enough of the comparison & results to keep it all on despite having to pull it for trans swaps. I can still pull the driveshaft and center section with it in place. But it's cramped.
I even got several compliments on the sound over the last couple of years.
LOCOMOTION Racing
