Liked 7,909 Times in 1,513 Posts
305 from George Yago's 1986 Camaro,qualified 1.006 under in bracket mode at Maple Grove pts meet 5-23-13. NHRA factor is 263 HP in Camaro, 248 HP in Malibu Wagon. This engine has only 43 passes and the best parts $$ can buy. Bow tie block,Manley rods ,cp pistons,bullet cam,SB lifters,7/16 studs,PAC springs,Comp roller rockers,Jeff Warren short block with Dave Layer heads and cast iron intake. Steffs Stocker oil pan,ATI damper . $5500. Bare 416 cylinder heads $185 pair, SBC cast iron intake manifold 055 prepped by Mike Walter $285, SBC alum intake manifolds 053 taken off street cars $35, Tuned port intake and tubes SBC 305 and 350.... Make offer ......CALL. M.J. 502 49 nine - 014 zero. Thank You Class Racer and Kenny.
Where are you located?
Robert |
I am located in Louisville, Kentucky. Thanks.....M.J.
