Old 01-26-2010, 09:04 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1970 #291 Square Port Heads and Holley Carbs
I have two sets of 3964291 square port heads. First set is dated I-10-9 and J-30-9 and are all rebuilt to stock specs with stainless valves ready to bolt on never run $1750. Second set is dated F-12-70 and B-5-71 and are a stock bare set with a brass valve job all cleaned and magged $1000. I also have two factory holley #4492 carbs used on L78 396 and LS6 454 applications for 1970 model year. The first one is complete dated 993 for $600 and the second one is missing the butterfly, choke and correct primary #6328 metering block with a #5271 in its place dated 035 for $500. I can be reached at 330-770-2517 and can send pictures with an email address.
dlv4540 is offline   Reply With Quote
