12-06-2019, 08:01 PM | #11 | |
Liked 549 Times in 228 Posts
Re: Duramax Allison issue
Barry Polley 758 A/SA California- No place to race! |
12-06-2019, 10:10 PM | #12 |
Liked 221 Times in 102 Posts
Allison was part of GM Hydramatic when the 1000 was developed . The Engineers from Indy work side by side with us in Ypsilanti . When GM went through bankruptcy Allison was spun off but the only Allison trans that remained with GM was the 1000 because it was in most of the 1-ton pickups . I think it's still built in Baltimore . Also Castrol developed the fully synthetic fluid Trans-Max , and later Allison re-named it Trans-Syn . It is a very good Automatic Transmission Fluid
12-07-2019, 10:18 AM | #13 |
Liked 184 Times in 37 Posts
Would the Trans Syn fluid be better in a 2001 1000 model Allison than the Dexron?
12-07-2019, 12:49 PM | #14 |
Yes! My 2003 has it. Smoother and less trans temp. Walmart is the best deal on approved Delvac Allison syn. I don’t use Castrol...
12-07-2019, 05:22 PM | #15 |
Liked 17 Times in 14 Posts
12-07-2019, 10:06 PM | #16 |
Works so well in the truck I’m tempted to try it in the race car.
12-08-2019, 07:39 PM | #17 | |
Liked 137 Times in 67 Posts
Jim Mantle V/SA 6632 |
12-16-2019, 06:43 PM | #18 |
Liked 30 Times in 16 Posts
Allison part #. Change every other oil change. Deep pan and Transynd 30k. Transynd doubles the service life in conjunction with additional ATF (deep pan). Don't forget to take the magnet out of the old filter, to put in the new filter.
