08-14-2020, 10:32 AM | #1 |
Liked 262 Times in 74 Posts
Onan Quiet Diesel questions
Anyone out there have any expertise on the Onan quiet diesel Gen sets with the 3 cyl Kubota D722 engine?
Ours is having a cold start issue. sometimes it needs extended cranking, Runs rough for 10 seconds or so before it straightens out. Huff's a bit of white smoke on start up. If I didn't know better I'd say it was flooded a bit. Once it straightens out ir runs fine for hours, makes power etc. I've had the injectors rebuilt, it has all new filters and lift pump, New glow plugs etc. Any one have some insight?
Steve Polhill 3520 STOCK, COMP |
08-14-2020, 11:55 AM | #2 |
Liked 1,629 Times in 502 Posts
Re: Onan Quiet Diesel questions
Mine will act that way when the fuel filter needs changed. I change my fuel filter about every 250 hrs and oil at 100 hrs. Have you changed the air filter? Mine get dirty pretty fast as my unit is mounted in the belly box on my toter when you are parked on the dirt there is quite a bit of dust generated by the cooling fan.
Mike Pearson 2485 SS |
08-14-2020, 12:09 PM | #3 | |
The filter is cheap enough it might be worth changing again.
08-14-2020, 12:54 PM | #4 | |
Liked 68 Times in 41 Posts
happens to me when the fuel level go low in my motor home after a refill .Has too suck it back up.
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
