05-13-2022, 10:06 PM | #1 |
Liked 43 Times in 19 Posts
Fast xfi
Can anybody tell me how to set the timing in easy to follow English. The instructions are a little confusing to me. This is on a TPI 350.
05-14-2022, 07:54 AM | #2 |
Liked 183 Times in 62 Posts
Re: Fast xfi
Go to ignition parameters. Set the box next to fixed ignition timing to whatever you prefer it be checked at (I use 30). Then check the box for fixed timing and click apply. Check your timing and if it doesn’t match move the distributor until it reads 30°. When done deselect the fixed timing box.
05-15-2022, 08:51 AM | #3 | |
Liked 67 Times in 24 Posts
Re: Fast xfi
05-15-2022, 03:18 PM | #4 |
Re: Fast xfi
And that's the way I read the instructions but it makes no sense to me. The instructions don't say anything about moving the distributer to set the timing.
05-15-2022, 04:14 PM | #5 | |
Liked 199 Times in 74 Posts
Re: Fast xfi
When getting into computers back in the 90s realized I had to think like the computer my process didn't matter to it. Plus you have to understand what it sees and what it doesn't. The ecu has no way to know what the actual timing is. It goes to the timing map and commands what ever the value is in the cell being used. The timing offset helps get the actual timing close to what the ecu will command after phasing but you still need to match it with a timing light to match what is commanded to the actual value. Have used the same method described above plus check it again after releasing the lock to match what cell is being used live on the laptop.
Frank Ferrucci ?/SA 1271 |
05-15-2022, 04:42 PM | #6 | |
Liked 2,314 Times in 455 Posts
Re: Fast xfi
05-16-2022, 09:13 AM | #7 |
Re: Fast xfi
I don't think that would work, but an MSD Grid might be helpful!
