HOME FORUM RULES SPONSORS CONTACT
Old 11-18-2022, 06:36 AM   #731
Liked 7,141 Times in 1,506 Posts
Default Re: Dumbo The Flying Elephant
A tip of the hat to Don Kennedy for his work on getting the problems handled. Thanks Don
Old 11-23-2022, 06:44 AM   #732
Went to the body shop yesterday, one side is done and the other side is being worked on. We should have it easily done before Christmas.
Old 11-24-2022, 07:20 AM   #733
Thanksgiving day and after our meal with the extended family (26 I think) it will be a nice quiet day in the shop without interruptions.
It didn't happen.
Old 11-29-2022, 12:01 PM   #734
Setting coil bind clearance on 392 DP engine.
Check PAC spring height gage for zero. Check height add .103 retainer adapter. Subtract cup and spring shims from gross number to arrive at installed height. Subtract valve lift from installed height to get open spring height. Measure spring height at coil bind subtract open spring height and the result is clearance or interference at maximum lift. Adjust accordingly to get the number you want.
The Pac mic is the best I have ever used for accuracy and repeatability.
Copyright ©2000 - 2022, vBulletin Solutions Inc.
