Old 12-28-2020, 10:33 PM   #1
Default It's About Time (Not MPH)
Yes, I'm the owner of a 96 Ford Escort, 2dr. 5 speed
It's only been, maybe 5 years?
The car is still in San Diego , in the possession of a racer / friend who handled the deal for me. Many thanks, and I'm not sure you want your name associated with this drivel.
Alex and I will probably do a relay pick up this weekend.
I built a quickie open trailer last month, expressly for this caper. Can't get a VIN and tag till my appointment comes up,...February 9th!
My plan for Phase 1 is to do whatever it needs to get it to run a few tenths under, for our local association races.
Going to get with Billy Nees Race Cars for some header pieces.
I've had the 19.5 Hoosiers for a while..Will find some rims for them.
I'll do whatever it takes to keep the engine from rocking and rolling and trying
to jump out from under the hood when I dump the clutch..Same for the front tires.
Phase 2 might be to pick up another engine and do it right, in case I ever want to go to Indy again. I doubt that would happen but I never say never.
Oh, and for those still awake who think these things aren't really race cars, you may be right . I might not actually be over there in that other lane, so just leave whenever you want ;-)
Old 12-29-2020, 12:18 AM   #2
Tom Meyer
Liked 354 Times in 120 Posts
Default Re: It's About Time (Not MPH)
First thing on rims and tires I see you have 13 tires make sure rims will clear your brakes. Aero makes wider wheel for the dirt cars. Solid mounts for engine and trans can be made by knocking out the centers and make insert from aluminum. Don't forget to look on dirt sites [central hornets is one] we see a few of them racing, for parts. I could hook you up with a guy that knows these cars. I would also call delta cams about a regrind quick turn around. Check out there facebook page.Tom
Tom Meyer 5240 SS Stock ???
Old 12-29-2020, 12:26 AM   #3
Something like so?
Send me the links, or post them.. Thanks
Old 12-29-2020, 12:32 AM   #4
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Originally Posted by Tom Meyer View Post
First thing on rims and tires I see you have 13 tires make sure rims will clear your brakes. Aero makes wider wheel for the dirt cars. Solid mounts for engine and trans can be made by knocking out the centers and make insert from aluminum. Don't forget to look on dirt sites [central hornets is one] we see a few of them racing, for parts. I could hook you up with a guy that knows these cars. Tom
Just have to get a set of the front steering knuckles and 13" calipers for 13" wheels.
Dave Noll, EF/S ,?/SA 6526
Old 01-02-2021, 09:48 PM   #5
Look what followed us home today...
I see Ford uses the same clear coat at GM..Black car,..in San Diego yet.
That's okay...Have d/a, will travel.
Old 01-03-2021, 09:54 PM   #6
HP HUNTER
Liked 372 Times in 129 Posts
Its nice to see you back in the game!
Old 01-07-2021, 03:16 PM   #7
Tom Meyer
Have you did any checking on adjustable pressure plate for this combo? Tom
Old 01-07-2021, 08:18 PM   #8
Frank Castros
Originally Posted by mark yacavone View Post
look what followed us home today...
I see ford uses the same clear coat at gm..black car,..in san diego yet.
That's okay...have d/a, will travel.
[img]https://i.postimg.cc/qdj7rnmm/20210102-
114510.jpg[/img]
nice!
Old 01-18-2021, 12:20 PM   #9
Here we go.
I gotta be nuts..A working A/C car with power steering ,that passes smog..Ripping all that out and throwing it in the dumpster. Don't ask where the Freon went to ;-)
I warmed this thing up first and drove it around the block a few times.I was able to power shift 2nd gear without destroying what's left of the clutch. I convinced myself that it won't take much to run under the index with this car.. But then , a friend reminded me that at the 4600 ' where my shop is, I'm giving up 9 tenths of ET.
...Okay ,so it will run close to the factored ET index.
Stay tuned for more parts in the dumpster. 55 pounds out, so far.
Old 03-15-2021, 11:51 AM   #10
doglover44
doglover44's Avatar
Liked 489 Times in 227 Posts
What class you plan on putting this into ?
Jake Biermann
