Old 12-21-2018, 05:06 PM   #791
Nmbr1GMfan
Default Re: H-I-J '76 Nova re-fit.
Working on valve cover stuff, not sure if this will work or not but I love trying stuff so here goes. Clutch manipulation will be a lot easier when I can get in the bellhousing!
Todd Greene
Old 12-28-2018, 06:59 PM   #792
Jeff Kempton
Jeff Kempton's Avatar
Liked 66 Times in 30 Posts
Originally Posted by Nmbr1GMfan View Post
Todd, would you be willing to share the manufacturers info for these tall Chevrolet script cast covers? They look like a great alternative for those wanting a retro look and using roller rockers (assuming they are made tall enough to clear without using spacers). Thanks!
Jeff Kempton is offline   Reply With Quote
Old 12-28-2018, 07:36 PM   #793
Nmbr1GMfan
Jeff, All the info is here https://www.yourcovers.com/valve_covers.html
Yes they are slightly taller than stock and do clear roller rockers, I like them because they're baffled.
Todd Greene
Old 12-28-2018, 07:38 PM   #794
Nmbr1GMfan
Update: Taking engine to the dyno Wednesday the 2nd. Hope to learn a few things next week.
Todd Greene
Old 12-29-2018, 01:18 PM   #795
6130
Liked 117 Times in 50 Posts
How many carbs are you taking?
Old 12-29-2018, 06:45 PM   #796
Nmbr1GMfan
Two, and a box of tuning bits. Plus extra headers, intake gaskets, collector extensions, mufflers, oils, and plugs.
Todd Greene
Old 12-29-2018, 06:55 PM   #797
Nmbr1GMfan
Plucked the engine today, going back tomorrow for a few hours to get started on the shocks and get the pedals back out. One cool thing I did today as I was trying to swing the alternator out of the way and zip tie it up, I thought better of it and put a nutsert in the inner fender, now it bolts up out of the way quick, easy and won't fall out moving the car around.
Todd Greene
Old 12-30-2018, 02:00 PM   #798
Nmbr1GMfan
Sunday morning brought a few hours of "car time". Got the shocks swapped out and the pedals out again.
Todd Greene
Old 12-30-2018, 03:08 PM   #799
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
(photos removed)
RE Post #804...Wait, Eight Hundred and Four posts in one thread???
Is the alternator in an independent cage that is bolted to the inner fender so that it can swing into position when in use and swing out of the way for service? How is it secured and tensioned? Mine is in a cage that bolts to the cylinder head (sbf). Did you have to fabricate a backing plate or are GM alternators body mounted? I have a mini on a V belt and a full size one on a Gilmer belt. The idea of getting the darn things out of the way is appealing. Is the meter in the panel wired to the alternator? Volts or amps? Sorry for the gibberish. I am fluent in Fordish but my GeneralMumble needs work...
Dale Shearon
68 Mustang 6394
Old 12-30-2018, 06:32 PM   #800
Nmbr1GMfan
Originally Posted by FireSale View Post
(photos removed)
The alternator merely bolts off to the side to keep it out of the way when working, or the engine is coming out.
Todd Greene
