Old 10-29-2018, 04:56 PM   #721
Pistol Pete
Pistol Pete's Avatar
Liked 795 Times in 210 Posts
Default Re: H-I-J '76 Nova re-fit.
Looks Great Todd....
"Pistol" Pete Dutko
Old 10-29-2018, 10:34 PM   #722
Nmbr1GMfan
Thanks bud.
Todd Greene
Old 10-30-2018, 12:40 AM   #723
6130
Liked 117 Times in 50 Posts
Wow, going back to page 13 of this thread- this car has come a long ways. Good job, Todd.
Old 10-30-2018, 09:23 AM   #724
Nmbr1GMfan
Thank you, it has been quite a ride so far. Now the hard part... making it haul ***.
Todd Greene
Old 10-30-2018, 11:54 PM   #725
6130
Well, not much of one. I give my daughter gas, telling her that when she stands sideways, I can't see her. I offer to buy her a sandwich every time I see her. I don't think she necessarily finds humor in old Dad's jokes.
You already have a proper Stocker engine for it, with a decent carb, right?
And you have your new headers, which you kind of played down, but looked VERY nice to me.
And I'm assuming the gearing is either correct, or close to it, because you're not changing the combo or the class.
And you have your new, lighter rear brakes.
And it looks like all the work that you've done was certainly of high quality...
I suspect that any teething issues with this one will be pretty short. The clutch needed some help, right? I can't remember if you said whether you did anything about that.
And I'm sorry, but those valve covers have to go...
Are there a lot of H, I, or J stick cars where you live? Do you have any significant reason to be concerned about heads-up races anyway, or is reliably running under index good enough?
Old 10-31-2018, 09:24 AM   #726
Nmbr1GMfan
I feel like we have a real solid combo, I think .70 under is no problem. I'm pretty sure the gearing isn't perfect because the starting line ratio is off a LOT (by 700 lbs car weight) so 2nd and 3rd are way off too. I have a new clutch linkage system I built (I won't show here) that may be hard on the clutch so I'm not putting the new one in till we test this out but here is what we will use eventually, when the racepak goes in.
http://www.blackmagicclutches.com/nexgenclutch.html
We need to be over a second under here at home so Indy is no problem. And yes, the valve covers and the rims will be dealt with, more on that later.
Todd Greene
Old 10-31-2018, 12:09 PM   #727
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Could you explain what ratio's are off a lot and what you will put in?
Old 10-31-2018, 05:46 PM   #728
Nmbr1GMfan
Glenn, The current SLR (starting line ratio) is 15.83 3.08 first gear and 5.14 rear gear, 3300lbs and 400ish hp would be an SLR of 18. So if it will spin harder in the lights I could go with a 5.38 gear with a 3.19 first and be at 17.16 SLR. May be worth a litttle E.T. I think the lowest first ratio I can get is a 3.28, the other trans ratios would fall in line based on dyno sheets.
Todd Greene
Old 10-31-2018, 09:52 PM   #729
Nmbr1GMfan
Borrowed a set of Weld 15x10 wheels to see if they fit, tire was wrong 28/10.5x15 but they fit pretty well I think, tight but the 10"ers fit. Compared to what I think are 15x8 wheel and a 30/9x15. Going with M/T 29.5/9.0x15 tire and a 10" rim I guess.
Todd Greene
Old 11-01-2018, 03:03 PM   #730
6130
Is there a mathematical formula for determining SLR on a stick car? I'd be curious to see how far off my old race car was.
