Old 12-23-2016, 07:41 PM   #61
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: '67 El Camino H/SA
Thanks to Perry Simpkins and Gary Jennings, no more c-clip eliminators.
Rich Taylor
I/SA - 321
Old 12-24-2016, 04:33 PM   #62
HandOverFist
New Budnick steering wheel looks right at home in there.
Rich Taylor
I/SA - 321
Old 01-24-2017, 03:01 AM   #63
HandOverFist
Best I could come up with for an alternator/mount...a lower mount was just not working out.
Ordered the wrong Wilwood rear brakes for my housing ends...awaiting replacements so I can stab the axles in and measure for back wheels. Also need to fabricate a d-shaft loop which will likely get welded to the crossmember.
Rich Taylor
I/SA - 321
Old 01-24-2017, 12:08 PM   #64
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Lookin' good!
I have the same alternator mount on my bracket Camaro, but I had to extend the top part a bit when I got tall valve covers. But I like it a lot, it's easy to get the exact tension on the belt you want and it holds it great.
Dave Muller is offline   Reply With Quote
Old 01-24-2017, 12:28 PM   #65
HandOverFist
It needed two 1/4" spacers to line the pulleys up...running a 46" belt.
Rich Taylor
I/SA - 321
Old 01-24-2017, 09:19 PM   #66
Alan Nyhus
Liked 799 Times in 236 Posts
Rich, Ram Air Restoration offers a driveshaft loop that bolts to the Chevelle cross member. -Al
http://www.ebay.com/itm/PONTIAC-OLDS...isMfNg&vxp=mtr
"That'll never work....."
Old 01-25-2017, 02:18 AM   #67
HandOverFist
Thanks Al...I may give that a shot as I don't have any suitable scrap lying about atm.
Rich Taylor
I/SA - 321
Old 01-25-2017, 01:23 PM   #68
It doesn't look too hard to fab up something like that..A chunk of pipe and some flat stock.
Old 01-30-2017, 03:35 AM   #69
HandOverFist
Back on four legs again. Axles installed and the Wilwood disc brakes clear 15" wheels with ease. Mounted some 30x9 Hoosiers on 5.5" BS wheels and they tucked in nicely, but they were a little tight on the frame side. I'll be ordering 5" BS wheels and that part will be finished.
Right now I'm battling a no fire situation with the new MSD 6530 box...
Rich Taylor
I/SA - 321
Old 02-02-2017, 04:13 AM   #70
HandOverFist
The "no fire" situation is solved and the beast is alive. Tip of the day...ensure your 12v switched source has at least 9v when cranking. 3v will not cut it...
Rich Taylor
I/SA - 321
