#601 |
Liked 11,017 Times in 2,265 Posts
I’m a nuts and bolts kind of guy. Patsy the IT person.
#602 |
I think we are done with the pink car. We have to get to work on Dumbo or he will miss Indy.
#603 |
Liked 359 Times in 135 Posts
Half a second slower for some reason?
Who owns this car, with the peace sign,mag wheels, and four on the floor? |
#604 |
Liked 67 Times in 28 Posts
Reason why it’s slower? One reason may be those slow runs could be used as the case for another HP reduction for that combo.
#605 |
Liked 498 Times in 235 Posts
Hope you get Dumbo going and figured out.
Jake Biermann |
#606 |
I’m hope to be at the sports with Dumbo again. I have a lot to do.
#607 |
How did that happen? Both generators and the motor home are all due for service before we go back out. Race car is ready for engine oil and filter change and the transmission is ready for the same treatment.
#608 |
We have some grease fittings that won’t take grease, brake chamber that’s leaking, and a seal on the front diff that is leaking. We will have it back at the Cat House to finish repairs. I want my motor home to be able to pass a DOT over the road truck inspection.
#609 |
The above picture is using a stroke checker and a modified spring checker to find a out when each spring goes into coil bind. Install all hardware on the head, measure with a height mike, subtract valve lift, and add shims. Piece of cake.
Thanks Ken Last edited by Larry Hill; 07-15-2022 at 06:15 PM. |
#610 |
Liked 2,768 Times in 980 Posts
Your new full time job keeps you very busy, praise the lord for your gift.
