Old 06-08-2024, 10:36 AM   #51
pmrphil
Liked 348 Times in 152 Posts
Default Re: OK, Stocker "valve jobs".
Originally Posted by Jeff Stout View Post
Converting to a canted valve ok if angled towards a port is needed? May only be 2 degrees worth.
No, ONE degree is all that's allowed. Wait until you try to get the rocker to comply .
Phil Molski
PMR Performance
S/C 1623
Old 06-09-2024, 08:03 AM   #52
Liked 10,758 Times in 2,236 Posts
If you installed the larger screw in studs to help stop some of the lift loss from deflection, a racer could regain the correct rocker valve angel relationship. I think
Old 06-09-2024, 02:26 PM   #53
pmrphil
Not if you're trying to "cant" the valve - then the stud would have to also have the corresponding "cant". Think big block Chevy, the valves are angled AND canted.
Phil Molski
PMR Performance
S/C 1623
Old 06-09-2024, 05:36 PM   #54
ProfessorRock
ProfessorRock's Avatar
Liked 48 Times in 24 Posts
This is a great post Billy. But i think most racers have no clue what we are talking about. Going to reply ,so not directed at anyone.
Rocketmancoatings
ProfessorRock is offline   Reply With Quote
Old 06-09-2024, 07:03 PM   #55
goinbroke2
Liked 395 Times in 154 Posts
This started because i didn’t have a clue, either! Lol!
Jim Miller
103 U/SA
Old 06-09-2024, 07:09 PM   #56
Well aware of BBC angel a cant of the valves. Spent a ton of money on a 68 427/ 400 project with 290 small plug heads. The car we got was from Wayne Shaw was a 69 350/ 350 car. I sold to John Livingston and he made the Tennessee Thunder car. NHRA made him change doors and put the key on the dash.
We enlarged the hole with an end mill to keep the tap drill from following the path of least resistance. And then spot faced the seat of the screw in stud.
Old 06-10-2024, 01:50 PM   #57
Dan Bennett
Liked 595 Times in 136 Posts
[QUOTE=Larry Hill;698408] ...NHRA made him change doors and put the key on the dash....
/QUOTE]
Flash of nostalgia for when rules mattered and a car had to be correct for the year. Little things like a pushbutton door latch and location of the ignition switch were no doubt a total pita but before "close enough" grey areas. No, can't think of a single performance advantage but somehow I liked it better that way.
Dan Bennett is offline   Reply With Quote
Old 06-12-2024, 10:17 AM   #58
Rory McNeil
Certainly must have been far fewer first gen 350 and B B powered, as well as automatic transmission equipped "Z/28" Camaros running in Stock and Super Stock back in the "old days". I still remember when a buddy took his 69 Camaro 427/425 Super Stocker down to Pomona, and the tech guy made him remove the SS emblem between the tail lights, since that was a COPO combination. Or when if you wanted to run a 69 Mustang 428 CJ car as a GT rather than a Mach 1, you needed to use the GT only gas cap. Things have certainly changed!
NHRA 6390 STK
M/S 85 Mustang
