Old 09-03-2016, 06:52 AM   #571
jcw31
Liked 6 Times in 6 Posts
Default Re: Ford vs Chevy Build-up
10 passes and you didnt bypass the controller,should have tried.Dont give up yet,maybe a chassis dyno is the right thing to do.
jcw31 is offline   Reply With Quote
Old 09-03-2016, 12:42 PM   #572
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Backed it off the trailer this morning and removed the controller. Took it for a spin down the state road in front of my subdivision...can't really see a difference in it which is troubling in itself. Rev limiter being capped at 5800 does not help either.
Rich Taylor
I/SA - 321
Old 09-03-2016, 12:44 PM   #573
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
Using a stock eec4 pcm?
Mitch Beri- The Motor City
Old 09-03-2016, 02:04 PM   #574
jcw31
Do the plugs look like they could use more or less timing?Can the cam be too big/ small? Is your cyl compression low?Too much or not enough gear?5800 might be enough rpm depending on combo.
Old 09-03-2016, 04:16 PM   #575
HandOverFist
Yes -
Leak down test from sometime last year...I think I did it correctly.
4.56 gear, 26" tire, 2.92 low C-4, 8" converter, Comp stocker grind cam. Nothing special on the heads...new valves with appropriate springs. Engine just feels flat and not pulling hard all the way down the track. Feels like it picks up a little at the top of third gear.
Rich Taylor
I/SA - 321
Old 09-03-2016, 06:24 PM   #576
jcw31
Can the lsa be too tight with too much int. duration screwing with the fuel inj.?The way you explained it, it sounds like big int. duration with early ivc I think there are other possibilities that you can get back your mid tq. /hp without sacrificing top end.This setup now only shows less than 300 hp.Dont give up on a car that is easy to repeat/comfortable .
Old 09-03-2016, 06:54 PM   #577
HandOverFist
Too many Stock Eliminator cars out there running these cams for that to be an issue I would imagine.
Rich Taylor
I/SA - 321
Old 09-03-2016, 08:16 PM   #578
7423
What controller?? Buy it new? Stock AFR will be 15-16 in high gear at 6000. Just getting the AFR to 12.5-13.0 will pick it up 5 tenths.
7423 is offline   Reply With Quote
Old 09-03-2016, 08:25 PM   #579
BRETV
Liked 776 Times in 199 Posts
I started out years ago with my 87 mustang M/SA set up just like yours and first time out went 12.50's. I had 30 inch tires with 5.13, but your 56's with 26 inch tires shouldn't be to far off. Key is the automatic cars don't like being reved up, I shifted at 5400 and went thru at around 6400. But the main difference is the computer. We had an old Accel in the beginning and later put a FAST in it. These are very good combos don't give up, just put a real computer in it. By the way I'm just finishing up my 92 mustang in SS/LA with same fuel injected 5.0 and we're gonna see if we can't get one to run well SS.
Bret Velde
2003 SS/LA (real soon)
BRETV is online now   Reply With Quote
Old 09-03-2016, 09:39 PM   #580
black88coupe
The factory rev limiter on that A9P should be 6250. Why 5800?
