Old 01-07-2019, 02:48 PM   #571
jbt352
Liked 2 Times in 2 Posts
Default Re: Woodfin's SS GT/TB construction series
Larry,
I will be interested as well.
We messaged back and fourth a few months ago.
We are doing a short bed S10 with a 6.0L for bracket racing
and are doing the final assembly on the rear end.
Thanks again.
jbt352 is offline   Reply With Quote
Old 01-07-2019, 09:54 PM   #572
Dragsinger
Liked 99 Times in 60 Posts
The Super 10 is built with a Chassis Engineering four-link kit #3513. You can go to the Chassis Engineering website, under "instructions" the kit is installed per those instructions at the ride height/axle height per the instructions.
The instructions also include a chart showing instant center for all possible locations. Tomorrow I will post a photo showing were the Super 10 links are located.
Note; it has a 32 x 14 tire.
Larry Woodfin 471W
Old 01-10-2019, 09:16 AM   #573
Hacksaw
Liked 311 Times in 175 Posts
Originally Posted by duke66 View Post
Been a while since we talked and we did finish my son's truck. With a 385, He has a best of 6.36,@ 108. 59% on the front.
Just wonder what your percentages are and the settings on the 4 link?
I built a SS/GT truck and the best I could get was 45% on the rear.
Old 01-10-2019, 09:23 AM   #574
jbt352
Hacksaw, how much weight was added to the rear of the truck?
I have seen some set up for bracket racing with a couple hundred pounds added. I just hate the thought of adding weight to a race car.
Old 01-10-2019, 11:15 AM   #575
Hacksaw
I had 90 lbs inside the rear crossmember, 30 on the inside pass framerail ahead of the rear wheel and 3 10 lb flat bars above the rear. Two 16 v batts at right rear corner.
Old 01-11-2019, 09:29 AM   #576
Dragsinger
In ref to the thoughts about weight bias. The height of the cab is a big factor in weight transfer because the center of gravity is higher than a car body. Plus, the driver sits higher than in a car.
Now that we have a 408 SBC w/aluminum heads of 700 horse the Super 10 leaves the line with a wheelie that is way up there. I have a video of the tail lights reflection off the track surface.
With each outing, I am making small adjustments to keep it under control.
Larry Woodfin 471W
Old 01-11-2019, 12:04 PM   #577
jbt352
Larry,
I may have missed it , but curious on how much weight you had to add.
Ours is not going to have that much power for the first few years.
Probably only around 500 to start but we want it to be as consistent as possible in the first 60'.
Old 01-11-2019, 12:40 PM   #578
duke66
We didn't add any weight to my son's 97. 59/41 front to back. Added about 80 in the bed and didn't make any difference so we took it back out. Our 4 link is close to your setup, Larry. Yours is a little farther out and lower than his. When we put the 31" tire on, I'll have to reset everything and should ended very close to yours, then. Thanks for your responses.
duke66 is offline   Reply With Quote
Old 01-11-2019, 01:41 PM   #579
jbt352
Duke,
How much power are you making and what kind of 60' times?
We have two cars with ladder bars that run in the mid tens to low 11's.
so this 4 link deal is all new to us.
Also wondering how muck preload people are running with these trucks with 4 links? Larry what are your thoughts?
Old 01-11-2019, 02:05 PM   #580
Dragsinger
Like is posted above, I experimented with weight in the rear but it did not change the chassis action for any detectable amount so I removed it all.
In the rear of the bed is a K & R air compressor, 5 gal cell that usually has 3.5 gals, and a 16-volt battery.
Larry Woodfin 471W
