#551 |
Liked 10,779 Times in 2,240 Posts
Got the honing plates on Dumbo with the crank still in the block to check cylinder straightness. Bottom line is we have to do something different, the cylinders were everywhere. .002 tight at 2-8 o’clock,10-4 slightly better, 12-6 loose tight loose, and 3-9 not bad.
I should have quit a little over a year after we started racing, because then I knew most of the answers! |
#552 | |
Liked 974 Times in 310 Posts
#553 |
Liked 693 Times in 205 Posts
I believe that Larry has the Mopar aluminum block. I have had friends that faced the same problems. You can try to hone it straight, but after you run it, the dimensions are all over the place. 8 Darton sleeves would be the place to begin or take a 100 lb weight penalty and use the cast iron BGE block.
#554 | |
Liked 1,598 Times in 583 Posts
The best is Steve Demirjian at Racing Engine Development in California. He is also the Engine Shop Manager of Darton and one of the foremost experts in sleeving blocks holding many patents on engine sleeves. http://www.raceenginedevelopment.com...odge-6-1-hemi/ |
#555 | |
Liked 805 Times in 341 Posts
Hidden Horsepower episode on cylinder honing. However last time a checked and it is probably worse now, he had a thirteen week backlog on block work. |
#556 |
It maybe a case of the block is not strong enough for the cylinder pressure generated under full load. My guess, and it’s only a guess, that the cylinders balloon and contract every cycle and become not straight and out of round in time.
For now I’m learning the do’s and don’t of the engine. With few parts available I’m doing my best not to destroy anything. I believe better sleeves will change things. |
#557 | |
Liked 54 Times in 24 Posts
Todd Gross 3323 FS/E,F |
#558 |
With me weighing 300+ the iron block would have to make a lot more power for me to consider it. If it not on the list I can’t use it. I try to walk on the knife edge on the rules, but I always have a set of gaskets and I am fearless going to the barn. Been doing this 30 some years and have been good every time, but all it takes is one third of the thickness of a hair (.001”) on the wrong side of a number and I will be disqualified.
#559 |
With the block having 16 main studs and location sleeves for the caps removing the caps quickly use to be difficult. Solution was a Gen III cap puller from Arrow. It’s great
#560 | |
Liked 734 Times in 385 Posts
Larry, If your weight and the car's weight does not change then all the iron block has to do is make enough HP to offset the difference in the weight between the 2 blocks. I do not know what the difference will be for those blocks. I do know that many years ago on a difference style engine / block making about 750 HP the iron block made about 15 more HP. Stan |
