Old 01-20-2022, 02:05 PM   #521
Liked 11,030 Times in 2,266 Posts
Default Re: Dumbo The Flying Elephant
Destroyed the ProTrans in the pink car. Sent trans to Joel’s, installed spare, all in getting car ready for the backup role. New plugs, re wire, (just for you Cody), adjust valves. What’s this? Very little compression on at least two holes one on each side. Leak test was double our President approval rating, so now it’s off with the heads........of the car.
Old 01-20-2022, 06:43 PM   #522
Frank Castros
Liked 2,789 Times in 982 Posts
Larry,
I don't mean to LIKE your blow by number but your analogy is priceless. So I must say you were still very quick with less than a totally sealed piece under the hood.
That Pink Pack is a bad *** racer.
Kudos to you.
Old 01-21-2022, 09:32 AM   #523
When the car broke the trans, the rev limiter did not catch it soon enough and bent a few valves. Of course some on each head. With the damage, it would be lucky to start and would not be able to run the index.
Old 01-21-2022, 01:46 PM   #524
doglover44
doglover44's Avatar
Liked 498 Times in 235 Posts
Hope you get everything ready by Spring
Jake Biermann
Old 01-22-2022, 09:14 AM   #525
Living in the middle of nowhere I try to keep a good parts inventory. So far I have enough parts for the first head. In a few days I should be smelling smoke.
Old 01-22-2022, 04:08 PM   #526
doglover44
doglover44's Avatar
Do you still have the pickup ?
Jake Biermann
Old 01-22-2022, 11:48 PM   #527
Yes
Old 01-25-2022, 09:34 AM   #528
Had to cut down face of valve to get chamber cc just a we bit larger.
Old 02-04-2022, 06:57 PM   #529
After we get the car fixed and the new shocks on, we have to rescale the pink car so we will be confident it will go straight as a "B" car.
I wonder what the weight is of a ZL1 Camaro is on the AMA Spec Sheet?
Old 02-04-2022, 07:50 PM   #530
Frank Castros
The "Pink Car" has best 60' efficiency for any class. That is for me one of the core elements for being elite class. Dumbo's right up there. Larry gets it. Patsy too!
