Old 08-03-2018, 10:18 AM   #491
Nmbr1GMfan
Default Re: H-I-J '76 Nova re-fit.
Help! The pump and lines were under a factory floor that would cover the original jack and such, the tank was partially under the floor with a hinged lid over the top portion of the tank. If I just put a firewall up will it be legal without the pump and tank covered? If I'm reading the rules correctly it should be ok with tank, pump, filters and lines mounted inside on the floor behind the firewall uncovered.
Todd Greene
Old 08-03-2018, 10:59 AM   #492
Hacksaw
Liked 311 Times in 175 Posts
There are many SS cars with the same tank and pump set up as you propose. So yes, you will be good.
Old 08-03-2018, 11:04 AM   #493
Hacksaw
Because you have a Hatchback, the back section needs to be " a separate compartment "
Old 08-03-2018, 12:03 PM   #494
FED 387
Liked 333 Times in 180 Posts
Todd I would immediately call NHRA tech and ask them how to do it. You might tell them your proposal and run it by them see if they will accept it otherwise look at late model firebirds/ camaris/mustangs for ideas on what others have done and is accepted
Old 08-03-2018, 04:31 PM   #495
Nmbr1GMfan
Yes sir, the plan is to have the firewall approximately where the carpet stops at the floor and go on up to seal at the hatch.
Todd Greene
Old 08-03-2018, 04:33 PM   #496
Nmbr1GMfan
Perfect, thanks!
Todd Greene
Old 08-04-2018, 06:18 PM   #497
Nmbr1GMfan
Feel like were back on track and getting a plan today. Laying out the fuel stuff and making bracket templates. Getting a better cooling system plan, a little underhood wiring and trying to figure out my ballast (legally).
Todd Greene
Old 08-04-2018, 06:54 PM   #498
FED 387
Looks like a double fuel filter before and after the tank why???
Old 08-04-2018, 10:27 PM   #499
Nmbr1GMfan
I've always run Aeromotive 100 micron pre and 40 micron post filters, catches trash from the tank and if the pump fails doesn't get into the carb or injectors. These filters have 60 square inches of filtering and full flow capabilities of 3000 hp. I've always had good luck with them.
Todd Greene
Old 08-04-2018, 10:36 PM   #500
FED 387
Ok was just wondering about fuel flow
