Old 09-07-2014, 05:50 AM   #41
JP
JP's Avatar
Default Re: SS Viper
Ok, I give up :-)
Will use my Flickr account instead.
Originally Posted by HandOverFist View Post
That makes no sense...no one posts more pictures here than I do lol.
Try a Photobucket account (free to a point) or another image hosting site.
JP is offline   Reply With Quote
Old 09-07-2014, 06:10 AM   #42
JP
JP's Avatar
Ok, lets try to continue the build story.
As I've been runinng a Viper business for many years (not now though) we had many choices picking headers. We dynoed with 4 different sets, didn't see much difference.
Ended up with a set of American Racing Headers. Nice work, perfect fit. Probably not the best performing set, but good enough for us.
IMG_3911 by j.phersson, on Flickr
The exhaust routing and frame on a Viper makes it impossible to exit headers under the car, this is the only way to do it.
2012-04-21 17.56.57 by j.phersson, on Flickr
Old 09-20-2014, 05:39 AM   #43
JP
JP's Avatar
We also decided to beef up the rear Stabilizer bar, the first one was in our opinion a bit weak, so we ended up with a tube inside a tube style. Sort of what several ProMods are using.
I wanted it as rigid as possible since we use a 3-link instead of 4-link. It's A non tested solution and I think this will help to make the 3-link work as we want.
A CAD rendering and the final product.
Old 09-20-2014, 06:00 AM   #44
JP
JP's Avatar
It's been a long process and many coold winter nights, so what we initially thought was a good solution have changed.
Our first plan was to drive it with a 4-speed Jerico, but when NHRA made it possible to use a 5-speed we decided to swap to a Liberty Equalizer. The Equalizer is not a small gearbox, so we were not sure if it would fit. We used a empty case to see if it was possible. I can promise it was tight but it did fit between the frame rails.
The Viper engine sits way back in the car. To make it possible to shift the gear box we moved the Shifter location forward 5" and fabricated a shifter head with a "bend" to move it additional 2" forward.
