Old 07-19-2014, 10:23 PM   #41
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Question Re: Hi all! New Guy here, Low Buck Comp build, E/ED
There is a guy on another sight putting a set of ls heads on a ford 6,maybe you should look into that.
7015 E/SA Sooner Storm
astikhossw is offline   Reply With Quote
Old 07-22-2014, 07:38 PM   #42
MICROMACHINE72
Default Re: Hi all! New Guy here, Low Buck Comp build, E/ED
not legal in the class we were going to run.
MICROMACHINE72 is offline   Reply With Quote
Old 07-24-2014, 09:35 AM   #43
cutta
cutta's Avatar
Liked 5 Times in 2 Posts
Originally Posted by MICROMACHINE72 View Post
Definitely heads and intake. first motor with a very flat power curve gave up at 367 hp.. only 6500-rpm. I needed at least another 100-125hp to make it even fee sable. The 5.4 mod con rods could not take the heavy TRW slugs either. even with max lightening, piston-pin. Motor needs custom pistons, big dome, big$$$ and alumn. rods, no doubt, I new that going in.. I think the flat tappet cams would have worked, but needed a much better head than my home ported 240 stocker. I may revist this some day, but I was itching to go racing, and a $1500 355 sbc with Killer Rons toilet on alky makes 550+hp. too easy and cheap to go much faster for now!
If you revisit the build down the road I would try to get in contact with Steve Ambrose. He ended up designing a billet cylinder head for his straight 6 ford but ran stock heads before that I believe. He may either have some of those older heads available or maybe able to give you some direction on your build.
Adriel Paradise, Paradise Racing Team
Driver/Crew Chief(at least my dad claims me to be)
B.S. Mechanical Engineering, University of Arkansas
cutta is offline   Reply With Quote
