Old 04-23-2021, 09:16 AM   #481
1matcoman
1matcoman's Avatar
Liked 355 Times in 136 Posts
Default Re: Dumbo The Flying Elephant
Old 04-23-2021, 10:23 AM   #482
340Cuda
Liked 805 Times in 341 Posts
Originally Posted by Keith 944 View Post
Robbie welch just had a tire blowout down in Georgia and is asking the same questions
which one did you buy, how much, do you have a link?
Thanks
Like Robbie I blew a trailer tire this weekend so it is a good time to get a TPS, been thinking about it for a while.
Very interested in reviews both pro and con.
Thanks!
Bill
Old 04-26-2021, 08:27 AM   #483
Liked 10,763 Times in 2,237 Posts
Consolidating information from working books to a permanent reference by category. I’m to old to remember and Dumbo is more complicated than I ever imagined. Today is bread crum organize day.
Old 04-26-2021, 01:21 PM   #484
MR DERBY CITY
Liked 7,992 Times in 1,525 Posts
eezrvproducts.com. ........this tire pressure system monitors the pressure and temp of tires. I have used it for a few years and highly recommend it.....
Old 04-26-2021, 02:33 PM   #485
^^^^^^^^^^^^^^^That's the one we use^^^^^^^^^^^^
Old 04-28-2021, 09:01 AM   #486
To my surprise the largest, most pages, section of my notes is the suspension section on the four wheel scales.
Old 04-30-2021, 07:18 AM   #487
For me the biggest question during dissemble is why? Why is there more ware on this side and not the other. After noticing change comes the questions; does it need fixing and if it does how?
Off topic but we are updating our gages in the Cuda to Classic Instruments 40* to 220* water, oil, and trans temp, plus the oil pressure gages.
Old 05-02-2021, 06:43 PM   #488
I removed a piston and rod. Checked the stretch of the rod bolts and the bolts matched the information on my build sheet. When relaxed the numbers agreed again. No sign of cap fretting or back side of bearing insert micro welding itself to the rod. Rings seemed to take to piston and cylinder wall. Top two rings were separated by about 120*, the oil rails were lined up over each other. Was that the reason the top of piston had a little extra carbon build up?
It will be good to know how round and straight the cylinder walls stayed. Our toy airplane engines ran well when they were round and straight.
Old 05-09-2021, 06:15 PM   #489
Selling the Private Lee has been way more time consuming than thought. I'm still finding parts.
I'm sending off a couple of test valves to be coated, I sure hope it will extend the service life of stuff.
Old 06-16-2021, 07:21 PM   #490
Got to finish the boat, then after the Norwalk races it will be focused on Dumbo. We hav a new trans to test and ratios to try
