Old 06-04-2025, 11:29 PM   #31
GUMP
Default Re: Coming Soon.....
The rule book is quite clear on this.
ALL 2008 and up cars are allowed a 9" and an NHRA approved suspension.
The corporate transmission rule applies because the Supra is built in a joint venture with BMW. BMW has a history of running GM transmissions in their cars.
Not one rule was changed to allow this car into the guide.
Daren Poole-Adams
NHRA Stock/SS 2007
Old 06-05-2025, 07:46 AM   #32
Bobby DiDomenico
Liked 103 Times in 53 Posts
That is interesting information, I had no idea NHRA changed the rules so much. Was this driven/forced by the acceptance of the V10 Drag Pack Challengers?
Old 06-05-2025, 07:58 AM   #33
Eric Merryfield
Eric Merryfield's Avatar
Liked 503 Times in 131 Posts
Smile Re: Coming Soon.....
It has a TH-400.
This is interesting, I'd like it better with a stick, but I'm sure the automatic will make it more driveable for most. I'd fit in it. Key is a close fit cage, done with care. Factory ECU or aftermarket, I use VF tuner for my street/strip toyota trucks. What Chassis shop is doing the build?
Eric
Eric Merryfield 1883 STK
Old 06-05-2025, 08:10 AM   #34
Liked 11,010 Times in 2,263 Posts
It could use a mail truck transmission.
Old 06-05-2025, 08:56 AM   #35
west coast
Liked 230 Times in 75 Posts
This has gone to 7 degrees of Kevin Bacon or should I say 7 degrees of GM. NHRA new slogan should be SHOW ME THE MONEY. Just fallow the money. The history of nhra was built on providing a safe place to race and done safely but now they rarely even check the minimum of any safety device, let alone following there own rulebook that is not safety related items. What is the point of the rule book anymore, run what you brung.
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 06-05-2025, 09:13 AM   #36
1347
1347's Avatar
Liked 1,032 Times in 283 Posts
Originally Posted by Rory McNeil View Post
Unless the rules have changed, how does a General Motors automatic transmission bolt up to a Toyota (or BMW) engine, and even more curious, how does a Japanese car get around that pesky rule that has always required the transmission (and rearend) being used, to be of the same manufacturer as the car? Or did Toyota buy GM while nobody was looking? I really doubt that this so called "Production" Toyota car is available at the Toyota dealership with a GM Turbo 400 transmission connecting the engine to the , I assume, Toyota rear axle assembly.
How did Ford get away with running Turbo400 transmissions in the Cobra Jet cars?
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 06-05-2025, 10:15 AM   #37
west coast
Same 7 degrees of gm. Jaguars used th400 in the 70s early 80s at one point ford own Jaguar. But they also own Cummins at one time also, turbos for all Fords with no hp rating change
Old 06-05-2025, 10:22 AM   #38
GUMP
Do any of you remember the thread that I started on AMC transmissions a while back...
Daren Poole-Adams
NHRA Stock/SS 2007
Old 06-05-2025, 12:03 PM   #39
SSDiv6
GUMP is correct.
The 5L50 and 5L40-E BMW transmissions were manufactured by GM.
Old 06-05-2025, 12:34 PM   #40
No. This is the production car. It will run in the normal Stock Classes.
Okay, so it will be showroom available?
Emissions compliant ? Cat-cons? EGR or latest technology?
CAFE numbers?
How many thousand miles of warrantee?
Financing? Trade ins?
Dying to hear ;-)
