Old 02-25-2025, 03:57 PM   #31
Liked 10,714 Times in 2,230 Posts
Default Re: HP on Monday?
You can be to light for the class or to heavy for the class. The car has to fit between a minimum weight and a maximum weight either one will get the run DQ.
Old 02-25-2025, 09:04 PM   #32
Cglrcng
Cglrcng's Avatar
Liked 334 Times in 185 Posts
The AHFS was triggered with the clocks at 1.300 under index (as the AHFS rules state "any run of 1.30 Under Index" shall trigger an immediate HP Reducution or Increase. Regardless of any possible fuel, weight check, or teardown or other DQ or anything else that happened after that trigger point. He did it, it happened, and the AHFS takes over from there. Any possible rules infractions don't change the AHFS triggering which is pretty much plain as day. The added HP is also spelled out in the formula and immediate.
NHRA posting (publication on nhraracer.com), is just a formality and notification to the rest of the world at
large, as multiple events can occur at different locations at the same time.
The Final Q sheet and ladder may, or may not contain DQ'd (or even
successive Qualifying/Class Ladders in
a case I know of), or withdrawn racers
(competitors), originally entered during
a specific event. As they are usually
removed from further competition.
If a particular pass is disallowed (weight/fuel), but the competitor is not removed from competition, as far as the
AHFS violation (more a trigger point for
Immediate action as required by the AHFS rules), the pass still exists, does it not?
I hope and pray the above comments about certain substances was posted in jest and purely misplaced sarcasm. Please tell me it was.
I found that out last April.
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can!
Cglrcng is offline   Reply With Quote
Old 02-25-2025, 09:10 PM   #33
Cglrcng
Cglrcng's Avatar
Sry, that last sentence belongs up 2 paragraphs. I am not editing it now.
I do not feel bad for the triggerman, I feel bad for others in his class. If you can fly, let the bird loose. We can build you back, bigger, faster, stronger Steve...lol.
Old 02-25-2025, 09:56 PM   #34
Brett C
Liked 1,018 Times in 217 Posts
Not sure why people seem to forget that all of this is at the sole discretion of the sanctioning body. My 1 cent.
Brett Candies
4192 Stock/SS
God Bless America
Old 02-26-2025, 12:24 AM   #35
MR DERBY CITY
Liked 7,938 Times in 1,519 Posts
So, racers want the AHFS to work….but not at INDY ..So, when a racer runs -1.30 under at ORLANDO , the run does not make the Q sheet ?? ….racer receives 15 HP BUT does not tear down ?? Gonna be a RUSH on 350 300 HP heads in the next few weeks.
Old 02-26-2025, 08:43 AM   #36
Doug Hoven
Liked 855 Times in 164 Posts
I doubt it. The 350/300 in a 69 Camaro pretty much got killed 2 years ago. Even though the 255 is at 295 now, I don?t think it is worth the extra 12 hp to make the switch to a 350/300.
1189 F/SA
Defunzalo Racing Enterprises
Old 02-26-2025, 09:01 AM   #37
Bobby Lundholm
Liked 127 Times in 49 Posts
With the aftermarket heads it's rated at 291
Bobby Lundholm 3516 G/SA
Bobby Lundholm is offline   Reply With Quote
Old 02-26-2025, 09:26 AM   #38
jimmyparker
Liked 309 Times in 88 Posts
Mainly the result of 15 year old indexes and zero tech on cylinder heads and intakes.
jimmyparker is offline   Reply With Quote
Old 02-26-2025, 09:53 AM   #39
Doug Hoven
The 350/255 with a replacement head is at 285. My guess is if there?s a rush to change heads, that?s what they?ll be more likely to do.
1189 F/SA
Old 02-26-2025, 10:58 AM   #40
Bobby Lundholm
That's a better option than the 300 combo at 291.
