Old 03-12-2024, 05:39 PM   #31
Pat6868
Liked 93 Times in 29 Posts
Default Re: Beware of Summit Branded braided hose!!!
Anyone using PTFE? If so, care to share results?
Pat6868 is offline   Reply With Quote
Old 03-12-2024, 06:25 PM   #32
1legjerry
Liked 72 Times in 15 Posts
I use XRP. I bought a Fragola fitting once because i heard good things about them I throw it in the trash as soon as I compared it to a XRP.
1legjerry is online now   Reply With Quote
Old 03-12-2024, 07:15 PM   #33
Angelo DiTocco
Angelo DiTocco's Avatar
Liked 189 Times in 48 Posts
yes - on all the gauge pressure lines & of course the brake hoses
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
Angelo DiTocco is offline   Reply With Quote
Old 03-12-2024, 08:10 PM   #34
jmantle
Liked 172 Times in 81 Posts
Originally Posted by 1320racer View Post
there's nothing to pass up. The customer chose to buy junk made in china because it's cheaper than hose ends and hose made in this country.
Summit sells Aeroquip which is made in the USA.
I've always been a fan of Aeroquip hose with their AQP inner tube but I would be surprised if it's still made in the USA. Aeroquip is owned by Danfoss, a Danish conglomerate who has manufacturing facilities all over the world. You also have to remember hose has a life no matter who makes it. I worked on heavy equipment before i retired and have seen hydraulic hose 10 years old that you couldn't bend and if you did, the inner liner would break up and come out in little pieces.
Jim Mantle U/V/SA 6632
jmantle is offline   Reply With Quote
Old 03-12-2024, 08:20 PM   #35
CMcAllister
Liked 920 Times in 259 Posts
I'm about to give up on the rubber liner stuff and go to the Teflon lined hose for everything.
Someone tell me a down side to it, other than cost.
Old 03-12-2024, 08:29 PM   #36
Steve Sullivan
Steve Sullivan's Avatar
Liked 31 Times in 15 Posts
"1320 racer" Why the administrator of this website still allows your obnoxious rantings on hear is beyond me.
You're obviously a legend in your own mind. In everybody else's, your an irritating buffoon.
Steve Sullivan is offline   Reply With Quote
Old 03-12-2024, 08:57 PM   #37
SSDiv6
If you want a great braided hose designed for motorsports, that will not collapse, that is compatible with all fuels, retains, and does not permeate or leak fuel vapors, I recommend the Goodridge G-Line XF 811 hose. Due to having a full length Teflon liner, therefore, it requires the use of Goodridge fittings also.
Another option is using general aviation steel braided hoses that meet the requirements of MIL-H-83797 or FAA-TSO C53a, Type A such as Aeroquip 601/AE701 hose and it is compatible with AN and MS fittings. A good source for the Aeroquip hose are stores like Aircraft Spruce.
Both of these hoses do not have a shelf life. There are some MIL-SPEC and SAE spec hoses that have a limited life of 10 years.
Old 03-12-2024, 09:00 PM   #38
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
nuff said, you're a moron and a hater going back at least 5 years!
I'm here to stay get used to it My opinions and advice or no less valid than anyone else posting here.
Old 03-12-2024, 09:08 PM   #39
SSDiv6
Danfoss acquired Aeroquip from Eaton and all products are still made 100% in the USA.
Old 03-12-2024, 09:21 PM   #40
Jim Hawkins
Liked 115 Times in 35 Posts
After 45 years working on forklifts I can tell you all rubber lined hose will leak no matter who makes it. I have built thousands of hoses from primarily Aeroquip and Parker. Hose when it breaks down will sweat out the liner or pin holes or in the case of hyd. hose burst if the stainless reinforcement gets compromised.
Having 20 year old fuel hose on a race car is not smart.
PTFE hose seems to me is way less prone to failure than rubber used for fuel.
I have a couple street cars I plumbed with that stuff for fuel and has never leaked after many years and sitting with fuel in them.
Fittings are steel and as such heavier and bigger for industrial applications.
PTFE may not have as tight a bend radius also.
This may not work or have the "look" most want on their race car.
PTFE is also trickier to assemble if you use reusable fittings.
I am replacing the fuel line from front to rear on the race car with PTFE and will never have to do it again. The tight bends under the hood and back at the cell will stay rubber but be replaced periodically.
Jim Hawkins is offline   Reply With Quote
