Old 09-14-2016, 09:54 AM   #31
Rusty Davenport
Liked 101 Times in 27 Posts
Default Re: Your experience foot brake vs. 2 step regarding ET
Originally Posted by Danny Ashley View Post
Plug the accelerator well tubes
Hey Danny sounds like what I've been looking for......but please don't leave us hanging.....can you go into a little depth on the "accelerator well tubes" PLEASE SIR or anyone else who has done this.....THANK YOU
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 09-14-2016, 10:39 AM   #32
Rusty Davenport
Is that the same as "SECONDAY ACCELERATOR WELL TUBES"
Old 09-14-2016, 11:19 AM   #33
Danny Ashley
Liked 110 Times in 29 Posts
The accelerator well tubes are the outer 1/8 inch diameter brass tubes in the air horn. They need to be plugged or removed for 2-stepping. However it isn't necessary, but will help the rich condition the moment the 2-step is de-activated. I have had racers with O2 sensors tell me their A/F would go as rich as 10.5 the moment the trans brake was released. I was told my someone a lot smarter than me that while on the 2-step puddling occurs in the intake because of the cylinders being canceled and the moment the button is released the excess fuel enters the cylinders causing the over-rich condition. My preferred method was to tap the tubes for a 3-48 stainless steel set screw. This allowed the racer to go back to foot-braking simply by taking off the airhorn and removing the set screws. You can just pull them out and if you decide to install them just flip them around for a press fit as they are swedged from the initial installation. They should be staked in regardless as they have been known to fall out even from the factory. Hope this helps.
Danny Ashley is offline   Reply With Quote
Old 09-14-2016, 07:52 PM   #34
j gardiner
Liked 55 Times in 29 Posts
I run my secondaries on my q-jet as loose as I can when I foot brake, but when I 2 stepped it would stumble. I tightened the secondary spring 1 turn and it was perfect.
j gardiner is offline   Reply With Quote
Old 09-14-2016, 09:01 PM   #35
Todd Hoven
Guest
Posts: n/a
Originally Posted by mat H/SA View Post
with the 2 step??
yes, the only way I could hit the tree in that car
