Old 08-05-2016, 06:17 PM   #31
Spyphish
Liked 679 Times in 180 Posts
Default Re: 1966 Coronet stocker
Engine compartment prep for paint. Tried a cleaner Cajun Brown which you cut with water. Did great. Treated rust with Ospho and then Bull Dog prep. All this is new to try so we will see. Protect the patina project.
ID:	35416   Click image for larger version
Old 08-21-2016, 06:11 PM   #32
Spyphish
Engine room, tubs, front end with disc brake upgrade and overhaul done. Motor delivered to Reher. Dana rebuild next.
ID:	35843   Click image for larger version
ID:	35844   Click image for larger version
Old 10-12-2016, 08:32 PM   #33
Spyphish
Well dana still not finished but Reher motor done. Should qualify.
Old 10-13-2016, 07:42 AM   #34
goinbroke2
Liked 395 Times in 154 Posts
793lb, 1025hp, I'd be concerned it will twist it into a pretzel! LOL!
Wow...impressive numbers to say the least.
Yeah, it "should" qualify.
Old 10-20-2016, 12:53 PM   #35
pfordamx
Liked 7 Times in 5 Posts
Is this going to be ran in stock or superstock? with that kind of power i'd assume the motor was built for superstock unless i'm just way out of the loop on the hp #s hemi's are making in stock these days.
pfordamx is offline   Reply With Quote
Old 11-07-2016, 09:02 PM   #36
Spyphish
Dana installed and motor waiting on proper mounts. Wildwood brakes all the way. Running in a few days or weeks I hope.
ID:	37638   Click image for larger version
Old 11-12-2016, 10:25 AM   #37
Spyphish
Test fit tight. Will have to shim K member down and big time haircut on passenger shock tower to use the Mopar covers. Factory stamped steel will fit.
Old 11-16-2016, 10:03 PM   #38
Don Morris
Liked 69 Times in 9 Posts
Stage V valve covers will fit and look good too.
I have a light turquoise 66 2dr sedan that runs B.
Don Morris is offline   Reply With Quote
Old 11-16-2016, 10:35 PM   #39
Spyphish
Motor back out and heading to frame shop after this D4 open this weekend. It will take an alignment but not the motor. Driver side hit somewhere in its history. Thanks for the info.
Old 11-18-2016, 02:52 PM   #40
Liked 10,762 Times in 2,237 Posts
Don's stuff is fast.
