#31 |
Liked 4 Times in 1 Post
There are aspects of motorsports evolution that are beyond the control of the sanctioning bodies, but should not be ignored. For example:
1) Today's 20 year old tech school student is learning on DOHC four and six cylinder engines, with electronic engine management, dual stage injectors, direct port injection (coming soon), variable cam timing, and of course, turbo and superchargers. Comp eliminator has already begun to embrace the newer designs. Dave Ring's altered has a Chevy Eco-Tec style 4 cyl, the Aragona's have been using DOHC Mopar/Mitsubishi type engines for a few years, and I hear Toyota engines will debut with at least one D-1 team in 2010. The days of the F/ED with a Pontiac block and a splayed valve Chevy head appear to be numbered. 2) The small block Chevy will go the way of the flathead Ford. Overhead valve V8's were in mass-produced cars by around 1949, and the last NHRA national event won by a flathead was 1963. Land speed racing still has a handful of diehard flathead racers, but they are the exception. The SBC will endure a bit longer thanks to bracket racing, but the writing is clearly on the wall. Already the LS-1 is widely accepted for hot rods and other projects that don't dictate the type of engine to be used. Scarcity and expense will phase out the SBC more and more. The SBC was the most common- other brands will diminish sooner. Who races an authentic Hemi Cuda anymore? How many Ford 427 wedges use original heads? How many 427 wedges period? 428's? 413's? 3) Used cars with carburetors are no longer on the street, and they are becoming expensive. If I had not already had a 69 Camaro that was in the garage for decades, I certainly wouldn't have paid for a first generation Camaro body for a stocker project. A '93 Camaro or Mustang body can be bought for under $1000, maybe even with a rebuildable engine in it. Of course, ten years from now, 2003 models will be dirt cheap. Time marches on. Adding all varieties of late model cars to the existing framework of rules would seem to be a tech-inspection nightmare. For now, S/SS has more participation than most other non-professional motorsports categories, so its short term survival is assured. But if you're serious about remaining viable as something other than a nostalgia series for more than another 5 years or so, it might pay to look at how another form of racing is doing it. The SCCA has a category called Touring, which is very similar to Stock Elim. While far from perfect, they have decent participation, in spite of not offering any prize money (winner gets a new set of tires from Hoosier). The T-1 class has the modern supercars- Ferrari, Viper, Corvette. By its nature, road racing has to be heads up, so they use factoring by means of added weight for the super-light Ferrari, bigger brakes for others, or in the case of the C5 Corvette, aftermarket headers (the other cars must use factory exhaust manifolds). The T-2 class successfully combines BMW's and Camaros with Saturn Vue (ie real-world hot rods). It goes down the line with T-3 to ordinary sedans from Honda, VW and Toyota.. They have the same arguments about factoring and fairness that NHRA has. Meaningful tech enforcement is just as challenging. It's just that they have found a way to include new and old, fast and slow, expensive and cheap, and yet there are fewer classes overall.
Tony Curcio 1860 STK |
#32 |
Good post Tony. I think that as an eliminator it is probably getting to be time to maybe have history repeat itself and somehow "evolve" Stockers into SS and start with a clean sheet in Stock.
(Did I just say that?) It would definitely involve some "juggling" though. Moving classes around to fit Stockers into SS would be quite a feat.
#33 |
Tony,
Actually, the Knight brothers still race a REAL R code Hemi 'Cuda in Stock in Division 3, Bowling Green is pretty much their home track. And the two fastest Chevrolet Stock Eliminator cars both still run original era cast iron heads. The small block Chevy has already been out of production in cars for longer than the flat head Ford was when it won its last NHRA event, and the small block Chevy is just about as strong as it has ever been in the sportsman ranks. There were a lot more small block Chevy engines built, over a lot longer period of time than the flat head Ford. Further, the factory still supports the small block Chevy. And so does the aftermarket, in a manner far more massive and complete than they ever did for the flat head Ford. Sure, DOHC 4 valve engines and EFI are common place now. But neither are new technology. EFI is at least 40 years old. And aircraft engines designed some 80 years ago were DOHC 4 valve engines with fuel injection. Not all new technology always moves down to grass roots racing. The complexity and expense of DOHC 4 valve stuff turns at least 5 times as many people OFF as it turns on. It isn't that Stock needs a "tiered" system. Stock just needs to stick to the original intent that it was intended for purely production cars off the showroom floor and the "tuner" cars, "builder" cars, and "export" versions go straight to some sort of Super Stock class where they belong. There's a place for the production showroom Challengers, and even the production showroom DOHC 4 valve Mustangs in Stock. They belong in Stock. The "package" race cars do not belong in Stock. The "package" cars are not the problem, they're a symptom of the real problem. The real problem is the massive disconnect between the people that control the sanctioning bodies an the people who are dues paying members of the sanctioning bodies.
Alan Roehrich 212A G/S |
#34 | |
"Evolving" the current Stock Eliminators cars into Super Stock not only is not really feasible, but it is something directly contrary to what NHRA wants to do. It would involved creating a ton of new classes in Super Stock (about the last thing NHRA would want) and recreating Stock (again, far more effort, time, and expense than NHRA would be willing to expend).
#35 |
Liked 804 Times in 168 Posts
Billy,
I am not sure where we will end up, but may I make 2 points. 1 - Don't blame the NHRA/IHRA with the evolution, the majority of the time the rule changes come from racers trying to get that little advantage and then asking the associations to legalize it. Larger rocker studs, ceramic lifters,aftermarket superceded heads, aftermarket stick trans. ,non original automatics(200's and 904's),just a small sampling. So next time you are lobbying for a new widgit to be legalized, think about it !! 2 - There ain't going to be more policing, the associations want to steamline the operations with less manpower. So don't dream up things that take more man hours. Some of the ideas I see and hear may be good ones, but the reality is they are not going to happen. My suggestion is less classes, come'on guys and gals we don't need all these classes. I suggest 1lb breaks and combine sticks and auto's for openers in the more populated classes. Yes, that will bring more heads up races and that is fine by me, that will make the ahfs work better, and add more excitement and appeal to stock eliminator . PS Billy, I was shoveling snow this morning and I found your "Wheezie", should i keep it in the freezer and give it to you at Atco ? I think balloon boy dropped it as he flew over. and by the way , I lost and arm recently, you gots it ?
Dave Casey 1330 STK |
#36 | |
Liked 4 Times in 4 Posts
I agree. Here's the problem. The kids coming up today either have no automobile knowledge and don't care to or the first thing they add to their new car is a huge stereo. They are more interested in driving around town with a trash can muffler than actually racing the car. But ,if you could generate the interest in racing then it would be best to have them run in a Pure Stock Front Wheel Drive eliminator with the only change being the exhaust cat back system. This might generate new blood into the sport. The draw back is that now HRA inspectors will have twice as much work and in policing and the cost will probably be prohibitive to the sanctioning body. Just grasping at straws, JimR
Jim Rountree |
#37 | |
As for the original question, where are we going as an eliminator, who knows. We've obviously, over the past 20 or so years have been slowly degenerating away from the original intent of Stock, for better (safety, wheelie bars, fuel cells) or worse (engine rules, relacement parts, some so-called paper cars, etc). The Indexes may be a step in the right direction, to add more of the performance back into S/SS. The AHFS, in it's current state, is at best, a total mess and will never work. Despite some people's requests, running S/SS off the records, or off the Index CIC-style like Comp will be the DEATH of modern Class Racing, as was shown eleven years ago in Division 1. Yet, despite the seemingly doom-and-gloom scenarios, S/SS seems to be alive, well and thriving, as you can tell by the number of entrants this past season during uncertain economic times. Other than the current AHFS format, I'd like to see NHRA leave stuff alone for a year or two, instead of some major rule change(s) that seem to happen every year, almost none of which were for the better.
Mike Carr, Tri-State S/SS Association President Looking for 2015 S/SS Race Sponsors Contact me if interested buffdaddy_1302@hotmail.com (724) 510-5912 |
#38 | |
NSS rules are NOT dial in, all classes run off indexes, if you run under the index you're out, run to slow and get beat. The indexes are run at 1/2 second intervals and you build your car to match the index. There are NO electronics allowed, foot brake only. And ....it's fun! JimR
Jim Rountree |
#39 | |
Liked 32 Times in 19 Posts
Even worse. We ran that way off dial in set at NOON in heat and raced at 2:00 AM with 1000 better Air..Several Years. We considered it miserable.. Then air stations and dial every run was better, still Dial In racing.... If you run at 10.50 against another 10.50 are you heads up or no break out? Isnt that like running a S/G car and a S/C or ST car on dial in? |
#40 | |
Dick, When you tech your car in you must declare your index, after that you cannot change it....if it's 11.50 then that's what you run off the entire race. If you go faster then you lose. If you run someone in the same class (index) it's heads up, break out and you lose, first to the stripe wins....no leeway. Think of super gas with different indexes 10, 10.50, 11...etc but with no electronics. Run too fast and break out, too slow and lose and the cars must look the same as when raced in the '60's and '70's with few exceptions like the AFX classes. If you google NMCA they have the rules and their schedule and I believe their first race is in Bradenton, go watch and talk to some of the guys, it's a good time. JimR
Jim Rountree |
