Old 02-07-2020, 02:25 PM   #301
Liked 10,793 Times in 2,244 Posts
Default Re: Dumbo The Flying Elephant
You FFFF Ford guys could have shared! LOL
Old 02-07-2020, 02:53 PM   #302
Hacksaw
Liked 312 Times in 175 Posts
New ring compressor worked perfect, the oil rails had the correct gap during installation.
I'm trying something different, assembling engine on the bench without using an engine stand. I'm thinking the heads are a strengthening factor to the aluminum block, that seems to move around a lot. Trying to assemble the engine without induced stress from hanging on engine stand. I'm not sure how to measure the results. Joel would ask me if I was trying pick fly stuff out of pepper. Many a truths are spoken in jest.
Larry: Your post reminded me of stories of engine builders that would hone their blocks with 160 degree water flowing through the water jackets. Makes you wonder.
Old 02-07-2020, 07:12 PM   #303
I was wanting to try 175* oil and 100* water in the honing plates, it would be almost like a heads up run.
Old 02-07-2020, 07:34 PM   #304
Frank Castros
Liked 2,741 Times in 967 Posts
It's all in the details. Richard Carlson author of Don't Sweat the Small Stuff is clueless.
Old 02-07-2020, 09:08 PM   #305
Had a good day today. Made an A2 steel crank key, degreed the cam in. I got my work-out in by moving the block , crank, and cam around from horizontal to vertical a couple of times. Installed all of the pistons but still have to tighten bolts to stretch. locktighted and torqued cam bolt. Its about supper time.
Old 02-12-2020, 09:00 AM   #306
Heads are on and valves adjusted. If any of y'all haven't tried installing push rods and rockers on a GEN III Hemi, don't, it almost can't be done.
Old 02-13-2020, 08:17 AM   #307
I will get pickup and pan on and mount engine on carrier. Will be heading south to dyno. I will try to get a video of a pull, it sounds pretty cool when it starts to really sing.
Old 02-13-2020, 09:24 AM   #308
pmrphil
Liked 348 Times in 152 Posts
Looking forward to it. I gotta say, thanks for the effort to keep this thread current - I check for it daily.
Phil Molski
PMR Performance
S/C 1623
Old 02-14-2020, 06:58 PM   #309
Adam Strang
Liked 96 Times in 23 Posts
Larry, Chrysler makes a special tool that holds the intake push rods in place that makes life a lot easier.
Adam Strang 1018 STK
Adam Strang is offline   Reply With Quote
Old 02-15-2020, 08:28 AM   #310
That tool is about $90 delivered, I bought one and two out of the four supports broke. It's made of plastic. In short I had to take the rockers off to find the broken plastic. The Ex. side gives me the most trouble.
