Old 06-10-2019, 02:20 PM   #21
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
Default Re: Fuel in intake
Thought I should add this. I talked to the carb guy today, he apologized for how things went and offered to do another carb on his nickle. Can't ask for a better conclusion than that.
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 06-10-2019, 02:58 PM   #22
Liked 10,759 Times in 2,236 Posts
Raw fuel through the vacuum port, I'm glad you found it.
Old 06-10-2019, 03:05 PM   #23
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
When i worked in the carb shop at AED in Richmond Va every carb we did we surfaced the ends of the body. Brand new castings from Holley are crap out of the box.
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
Old 06-10-2019, 06:40 PM   #24
Ralph A Powell
Liked 225 Times in 136 Posts
If you remove the power valve and use the the Holley power valve plug some have excess casting flash on the head look at it some are worse than others. Bolt the carb together install both new gaskets and 4 bowl screw gaskets torque bowl screws to 35 in lbs. Then take it apart look for pv plug contact in the cavity the plug head goes in on the main body it can keep the metering block from totally sealing to the main body. I have seen that a lot.
Ralph A Powell is online now   Reply With Quote
Old 06-11-2019, 08:24 AM   #25
GallopinGhost
Thanks, I put the PV back in, but I'll keep that in mind
Brian Carpenter
Stock 1358
