Old 09-03-2018, 09:02 PM   #1
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
Default Solid lifters in Stock
When the rule was changed to allow solid lifters in Stock eliminator engines that were previously hydraulic equipped, did racers change cams or just install solid lifters ? What typically would they set valve lash at ? Not looking for top secret info just a general idea.
I have seen solid cams run in engines (not NHRA stockers) with hydraulic lifters that seemed to work "ok" but never the reverse procedure,
Old 09-03-2018, 09:53 PM   #2
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Default Re: Solid lifters in Stock
Myself, I have just switched lifters. BUT, the pattern on the cam had to appear normal, I lubed the lifters just like installing a new cam. Put break in oil in the pan. Set lash and ran it for a Half hour at 2500. With a hydraulic cam there are no clearance ramps ground into it so I run lash tighter than usual. (under .010)
Dave Noll, EF/S ,?/SA 6526
Old 09-04-2018, 01:19 PM   #3
Rsmith38
Liked 28 Times in 15 Posts
I installed solid lifters on hydraulic cam and was told by a well known cam grinder to set lash at .004 - works fine!
Rsmith38 is offline   Reply With Quote
Old 09-04-2018, 01:50 PM   #4
David Lee
Liked 346 Times in 126 Posts
has anyone noticed a hp increase or a better et?
Old 09-04-2018, 04:47 PM   #5
Alan Nyhus
Liked 799 Times in 236 Posts
-With solids, you loose lift at the valve due to the lash under running conditions.
-With true hydraulics, the theoretical lash is '0'. In reality, there is some compression of the retained oil in the lifter. How much? .004? .006? More? less?
And since the lift is checked at '0' lash..... -Al
"That'll never work....."
Old 02-03-2019, 10:22 PM   #6
Rob Petrie E395
Liked 216 Times in 77 Posts
Going from non shimmed Hydraulic Roller Lifters to solid roller lifters. What would you expect to see as far as performance increase?
