Old 06-14-2018, 08:50 AM   #21
nhramnl
Liked 358 Times in 83 Posts
Default Re: Hoosier Slicks & front tires
I've run radial slicks on each of my TWO MPR Super Stock Cavaliers because when I need to be as quick as I can possibly be (like running for class or in a heads-up run in eliminations), they tend to give me a few hundredths. That's the ONLY reason I ever use radials. You sound like a guy who wishes his expensive, elephant-motored bracket car was still a legitimate class car.
Old 06-14-2018, 08:55 AM   #22
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Got zero desire to run Super Stock and both my cars are quicker and faster than yours.
Old 06-14-2018, 09:13 AM   #23
nhramnl
You've been down this road with too many people in the past, Ed. It leads nowhere. Discussion over.
Old 06-14-2018, 09:36 AM   #24
1320racer
1320racer's Avatar
what part of the FACTS and the TRUTH don't you like?
Is it the fact that radial wobble has nothing to due brand name or air pressure and everything to due with track prep and chassis setup?
Or is it the TRUTH that both my cars are quicker and faster than yours?
or maybe it's the FACT that a bypass kit, two -3 lines plumbed into your regulator will do nothing except lighten your wallet.
Old 06-14-2018, 12:51 PM   #25
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Originally Posted by nhramnl
On a bracket car? Why?
I will only run radials on my 9" tire bracket/Super Street car. I have a lot of reasons why, and can't think of any reason NOT to.
S/ST 51
S/C 53
Old 06-14-2018, 02:10 PM   #26
nhramnl
The reason is because there's no "margin of error" with them. They either dead-hook or spin. Stick cars can't use them at all, for that reason. With bias-ply tires, if you don't dead-hook, you still have SOME chance of salvaging the pass. With radials, you're done.
Old 06-14-2018, 04:44 PM   #27
Ed Wright
Ed Wright's Avatar
Only "radial wobble" I ever had with mine was from trying to run narrow wheels, like you would a bias tire. I use 14" wide wheels on my 13" X 31" MT radials, 13 psi, never spins or wobbles. Tubeless, they don't leak.
A-B-A tested MT, GoodYear & Hoosier, same day, even with all of them dead hooking, MTs were quicker. Hoosier was quicker than Goodyear, which was the slowest.
I blamed that on weight, GoodYears were/are about 5lbs per tire heavier than Hoosier. Hooked as hard as the MTs, but still slower. Most of the difference was in 60'. I don't know much, but I blamed it on weight, and maybe sidewall design.
Don't know if this will help somebody, or offend somebody. Hoping for the former.
Ed Wright 4156 SS/JA
Old 06-14-2018, 07:26 PM   #28
1320racer
1320racer's Avatar
my car dead hooks every pass! 60 foots low 1.20s to high teens. If you're spinning the tire, fix the car!
Old 06-14-2018, 08:13 PM   #29
Ed Wright
Ed Wright's Avatar
And, I have not experienced that. I don't know anybody I race with seeing that. Hardly ever see an automatic car on bias tires anymore. Likely just your car. Might need to go see DeWayne Custer.
Old 06-14-2018, 09:55 PM   #30
Lenny5160
Lenny5160's Avatar
x2, although I'm only going 1.40 to 60 foot. Been running radials on this car exclusively for over 20 years save for one set of MT 3056ST, which were deadly in 60 feet and no slower than the radials, but were somehow junk elsewhere.
S/ST 51
S/C 53
