Old 08-24-2016, 02:37 PM   #21
StockerStang912
StockerStang912's Avatar
Liked 21 Times in 7 Posts
Default Re: Your experience foot brake vs. 2 step regarding ET
We experienced a marginal performance improvement of .01 to 02 with a 2-step on a low hp Fox Body stocker. Would have to make a few more runs to have a better idea with reaction time, but certainly made staging easier/consistent.
To Bobby's point, we did not adjust fuel enrichment to accommodate the change so not sure if it's a true apples-to-apples comparison.
Greg Viscome
193 GT/QA
StockerStang912 is offline   Reply With Quote
Old 08-26-2016, 03:43 PM   #22
Jack McCarthy
Liked 477 Times in 117 Posts
my car hates it (as do i) kills me about .05 at least - more in bad air ....
and i cannot stand that sound ...
so im stuck in the 60s footbraking it
captain
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 09-01-2016, 07:35 AM   #23
Robert Simpson
Liked 20 Times in 12 Posts
Originally Posted by dean ribeiro View Post
Rusty-
My experience has been .008-.012 quicker in 60ft ET with a two step switch (same launch RPM) This equates to .016-.024 improvement in 1/4 ETs. It should be noted that to leave matted off of a 2-Step, the carb requires a different set up (think secondaries). My experience with fuel injection stockers mirror Eric and Bobby ( you stand to pick up a little more ET). I suspect this has to do with the amazing starting line efficiencies with FI (compared to the "quadra-bogs")
Feel free to call with questions buddy!
PS- I surround myself with much smarter people than myself! 😁
Dean could you better explain to me about adjusting the secondary for a FB two step? I have a street car that I Foot brake. I leave around 1500 and it flashes to about 3800. I tried a two step one time and while it reacted quicker to stumbled about 10' foot out and then cleared up. You can IM me with any details if you would like. Thanks
Robert Simpson is offline   Reply With Quote
Old 09-07-2016, 09:10 AM   #24
Rusty Davenport
Liked 101 Times in 27 Posts
Maybe someone will see this and reply but has anyone experimented with low rpm 2 step ......will the motor respond ok on the 2 step at 2000 ????
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 09-07-2016, 07:59 PM   #25
Rsmith38
Liked 28 Times in 15 Posts
Don't know about 2000 but my R/SA Jeep 4.0 leaves fine at 2550 - down from 3000 because the brakes won't keep it from pushing thru the lights!
4.0 is FI so can't say about a carb reacting.
Rsmith38 is offline   Reply With Quote
Old 09-13-2016, 03:05 PM   #26
Rusty Davenport
I'm finding out little by little with experimentation, and it gets back a little to what some of you hinted around to, the quadrajet does not like "rich" fuel mixture when leaving on the mat with the 2 step activated by the brake. It will sit on the starting line and hold the RPMS but when you let go the "rich" will usually make it leave terribly, even though it will run great with the same carb setup when running with the footbrake only.
MAKING THE 2 STEP WORK WITH THE QJET IS A CHALLENGE in order to get it to perform at its best especially on a stocker that doesn't have a transbrake and has to leave at much lower RPMS......by what I am seeing testing the 2 step requires leaner setup to run at least reasonably well.
Does anyone else have similar findings ????
Old 09-13-2016, 07:43 PM   #27
Danny Ashley
Liked 110 Times in 29 Posts
Plug the accelerator well tubes
Danny Ashley is offline   Reply With Quote
Old 09-13-2016, 09:30 PM   #28
Todd Hoven
Guest
Posts: n/a
I used to leave at 2200 with my 455 Lemans. I did what Danny said. blocked off the accelerator tubes and it left great. Always to the floor.
Old 09-14-2016, 07:34 AM   #29
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
I`ve been using a 2 Step anywhere between 2000 and 3100 rpm and the 60` times seem to be about the same. All of this with a V6 "Stocker". I`ve also gone back and forth with foot braking as well and prefer the 2 Step for consistency. Low horse, small carbed cars seem to be more consistent leaving at WOT. I also 2 Step my Super Pro car (big block Chevy with a 950 Holley, dual line lock set up) with the 2 Step around 1900 rpm and it leaves just fine.That's my experiences at least.
Lane Weber
Old 09-14-2016, 09:14 AM   #30
mat H/SA
mat H/SA's Avatar
Liked 14 Times in 8 Posts
with the 2 step??
mat H/SA is offline   Reply With Quote
