#21 |
Liked 460 Times in 91 Posts
ED, are u off ur meds again ????????????????????/
Bob Bender 144 O/SA 2010-2012 National Record Holder |
#22 |
address point number 3, where this has not been implemented anywhere, and until it has, class racing has much bigger fish to fry
Chad Rhodes 2113 I/SA |
#23 |
#24 | |
Gary Hampton '86 Z24,173 V6 CF/S #5824 (#78 in 2021) Last edited by GarysZ24; 11-08-2010 at 08:33 PM. Reason: I falsely referred to John Kelley, when it was Chad that made the credible points I referred to here. |
#25 | |
#26 |
Liked 26 Times in 5 Posts
Chad, I have read your arguments and one seems contradictory. You said that class racing has bigger fish to fry and that it is important to get younger people involved. You mean younger racers who do not have a lot of money to spend on a race car ?.... that would probably have to build a slow car, and would have to go in knowing they have a disadvantage from the get go ? Seems you could entice younger racers with smaller budgets better, if they knew they would have a equal shot. That might boost intrest. I have no problem with the worst red light rule, equals things up.
Thanks Ryan Smith 723R |
#27 |
Let's not have them get on the brakes and bring out the first or worst double break out rule.
Jerry Williams NSS/A, E/S, PRO E.T. And the "Grandaddy" of Gen III Hemi Performance...The fire inside me still burn's. |
#28 | |
Bottom line, my ideal may be awful (sorry no "e" in awful), but neither is not having a worse redlight adjustment made to the tree, to give the same pressure to the faster car in a handicapped race for his rt., as the slower car. In a heads-up race, both cars have the same pressure, so why not change the tree for handicapped races too. As far as I'm concerned, if it's not changed, then I'd like to see wheelie bars ousted from rwd stockers if they won't be allowed on fwd stockers too....
Gary Hampton '86 Z24,173 V6 CF/S #5824 (#78 in 2021) |
#29 | |
2002 Division 6 High School Champion 2007 Division 6 Pro Champion 2007 Division 6 National Open Series Stock/Super Stock Champion |
#30 | |
Liked 4,384 Times in 504 Posts
Chad, I'm not sure what math you are referring to but I've showed the math on the last thread. I'll show it again at the end of this post. Bill Dedman and his supporters are the only ones making sense. The rule clearly favors faster cars from a probability standpoint. Who cares if Bill is a bracket racer? I am a bracket racer too. Ladies and gentlemen, I don't know if you've noticed but from Friday-Sunday, Stock and Super Stock are in fact bracket races. I still have not read one single valid argument defending the rule as it stands, not even one! Unless of course "That's the way it is.. Stop whining...Bill is only a bracket racer, not a SS racer..." can be considered valid with their clear and concise reasoning. If the only thing keeping it from being changed however many years ago was a software issue, then there is no reason not to change it now. The Worst red light rule is currently in effect for Top Fuel, Funny Car, Pro Stock, Pro Stock Bike, Super Street, Super Comp, Super Gas, Super Stock Class, and Stock Class. Why not for Stock and Super Stock eliminations? As far as brackets, the rule should also be introduced and enforced in all classes, especially in Super Eliminator where both drivers leave off the top bulb at the same time with the crosstalk feature. Give me one good reason why the first guy to redlight should ever lose in Super? I'm guessing his dragster might possibly distract the other dragster's delay box.. Here it is in stat terms again. We will use discrete probability and analyze our sample space of four possible outcomes: both drivers green, first guy green and second guy red, first guy red and second guy green, both drivers red. In order for an event to be a "fair" event in the world of probability, all possible outcomes but possess equal probability, in this case each of the 4 outcomes should have a probability of 1/4 or .25. With our current system, the first two scenarios possess a probability of .25 (Probability of first guy going green = .5 AND probability of second guy going green = .5 so we multiply these to get a probability of .25 for this outcome. Same calculation for second outcome) However, the third scenario possesses a probability of 1/2 or .5. (Probability of first guy going red = .5 AND probability of second guy going green = 1 since he/she has already won. Multiply these and we get .5). The probability of the last event is actually 0 because currently it can't happen and we revert to scenario 3. Since each outcome doesn't have the same probability, this event fails the "fair" event test. Conclusion: The first driver to leave is 25% more likely to lose the race on the starting line than the second driver. |
