Old 12-18-2009, 05:54 PM   #21
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Wink Re: Thermoquad vs Quadrajet
I have seen many of the bowls vary in color from black to dark brown. Remember these "plastic carburetors" bowls were made of a polyfiber-resin materiel that is rather fragile. The "red" could have been a different resin compound they were trying out, but again, I have done hundreds of Thermoquads for Stock and Super Stock applications and never seen one of the "red" bowls. Jim
Old 12-18-2009, 10:46 PM   #22
Run to Rund
Liked 54 Times in 27 Posts
Default Re: Thermoquad vs Quadrajet
The 800 Qjet is easy to tell from the 750 once you have seen both. The outer ring (the primary venturi) is round in a 750, and larger with a protruding bump in it on the 800s. I've seen 800s on such unlikely stuff as a late 70s Olds 350. In that case, the linkage that opens the secondary throttle blades was restricted so they didn't open all the way.
Old 12-18-2009, 11:54 PM   #23
Jeff Lee
Jeff Lee's Avatar
The red bowl was marketed as a performance application. Mid-late '70's I think?
Wow...there's a Thermoquad.com site!
http://www.thermoquads.com/page203.html
CFM differences here:
http://promaxcarbs.bizland.com/thermoquad.htm
Jeff Lee 7494 D/S '70 AMX
Old 12-21-2009, 02:11 AM   #24
GTX JOHN
Thanks to everybody for the good feedback! I'll let you know by March how the Quad seems to be working out. John Irving
Old 12-21-2009, 10:13 PM   #25
Randy B.791
John if you go to a quadrajet put the thermoquad on jr. car.(n/sa) record with that carb i thought would be fast enough. See u after new years race at sac.
Randy B.791
Randy B.791 is offline   Reply With Quote
Old 12-22-2009, 09:58 AM   #26
Redlight
Danny, you gots mail.
Redlight is offline   Reply With Quote
