Old 12-20-2022, 09:46 AM   #251
TOSTO RACING
TOSTO RACING's Avatar
Liked 652 Times in 184 Posts
Default Re: 8.50 index build
This is your best engineered and best appearing car for 2022!!
5664 GHI/SA
1985 CAMARO RED H/SA
1985 CAMARO BLUE I/SA
TOSTO RACING is offline   Reply With Quote
Old 12-20-2022, 10:46 AM   #252
Todd Geisler
Liked 345 Times in 149 Posts
Originally Posted by TOSTO RACING View Post
This is your best engineered and best apperaring car for 2022!!
Was it the headlights???
Todd Geisler is offline   Reply With Quote
Old 12-20-2022, 02:15 PM   #253
TOSTO RACING
I decided this way before headlights lol
5664 GHI/SA
Old 01-18-2023, 04:34 PM   #254
C5 Pete
C5 Pete's Avatar
Wow, Todd!
As I’ve e followed along on instagram, this thread is the first time I saw it from start to finish!
Such an amazing job with super attention to detail.
Best of success to you, as long as you don’t line up next to me.
See you at the track!
BTW, did you know the NHRA is considering an 8.60 class for a national championship? Apparently, they’re looking to tap into the very popular 8.50 index racers and the drag and drive folks.
No throttle stops or delay boxes. Basically, run what you bring as long as it’s a door car. You’d fit in nicely!
C5 Pete is offline   Reply With Quote
Old 01-18-2023, 09:53 PM   #255
Todd Geisler
Originally Posted by C5 Pete View Post
Wow, Todd!
Thanks Pete!
I've since decided to leave 8.50 index to run the local Top Sportsman series. But that would be great if NHRA added a similar class.
Old 03-12-2023, 09:37 PM   #256
Todd Geisler
Sorry for the lack of updates.
Came home from the show and began to work on the chassis setup. Found the rear shocks were not sitting down at ride height length so I had to swap from the 80 lb coil springs to a 70 lbs. Put the car on scales as well as measuring and plotting the instant center.
Old 03-12-2023, 09:40 PM   #257
Todd Geisler
Next up was to put the car on the chassis dyno to work on the efi tune. Got the tuneup almost done when we heard a noise in the valvetrain and aborted any more runs. Took the car home to investigate.
Old 03-12-2023, 09:44 PM   #258
Todd Geisler
Pulled the passenger valve cover on the dyno and found 3 of the small bolts laying in the head that attach the exhaust stand to the intake stand.
Got home and took it all apart to inspect the thread inserts in the heads. False alarm, all was tight and threads were good. Can only assume those small bolts just never got tightened completely.
Old 03-12-2023, 09:46 PM   #259
Todd Geisler
Time to mount up a new set of M/T 315 Pro's.
Old 03-13-2023, 04:18 PM   #260
Todd Geisler
Next up was to finally put all the safety gear in the car. The seat belts were first, but it's a project. The seat has to come out to be able to reach the bolts for bolting them in. The driveshaft enclosure is really close to the seat, so it and the driveshaft have to come out to be able to unbolt the seat.
