Old 08-21-2022, 10:11 AM   #211
Todd Geisler
Liked 345 Times in 149 Posts
Default Re: 8.50 index build
One other little fabrication project was to make a bracket to attach the 10 oz c02 bottle to the side of the fire bottle. Pro Werks billet clamps finished off the mount. Need to drop the bracket off for powder coating.
Todd Geisler is offline   Reply With Quote
Old 08-30-2022, 10:57 AM   #212
Wayne Kerr
Liked 26 Times in 11 Posts
Hello Todd,
Please explain the shift linkage. I'm certain I'm missing something.
Thanks.
See you at the races,
Wayne Kerr
Wayne Kerr is offline   Reply With Quote
Old 08-30-2022, 11:02 AM   #213
Todd Geisler
The travel sensor on the transmission linkage can be used for numerous things when tied into the Holley Dominator EFI.
Can be used for reverse lights, shift indicator, neutral safety switch, high gear timing retard, as well as idle circuit fuel/spark map adjustments to keep from dropping rpm when put in gear. I’m sure there is even more it could do.
Old 08-30-2022, 01:52 PM   #214
Wayne Kerr
Thanks Todd, didn't know it was a linear potientiometer.
That splains it.
Wayne Kerr
Old 09-20-2022, 10:44 PM   #215
Todd Geisler
Monday (yesterday) was another milestone in the build. Was able to fire up the engine and with some help get the efi adjusted some. Went well, so the next move is to drop the car back off at the body shop to install glass, trim and some other small things.
After that it’ll be time to put the car on a chassis dyno to work on refining the efi tuneup further.
Old 09-22-2022, 07:54 PM   #216
Todd Geisler
C02 air cylinder mount powder coated and installed.
Old 09-22-2022, 07:58 PM   #217
Todd Geisler
I came to the realization that I didn't have any place to keep my things like tire pressure gauge, cell phone, sungless, or water bottle. Simple solution was to make a dragster glove box and attach it to the weight bar tabs on the passenger side rocker bar. The Mustang is small enough inside that I can reach while in the driver seat (just not belted).
Old 09-22-2022, 08:01 PM   #218
Todd Geisler
Finally got around to installing the carbon tube protectors.
Old 09-22-2022, 08:05 PM   #219
Todd Geisler
Car sitting ready to fire for the first time.
Old 09-22-2022, 08:07 PM   #220
Todd Geisler
So Monday evening was the magic day. The next milestone in the Mustang build... First engine firing in the new car.
Click the link...
