Old 03-20-2021, 09:53 AM   #191
Billy Nees
Liked 7,783 Times in 1,743 Posts
Default Re: Not for Nuthin' But Close!
I've spent a couple of hours removing the power brake booster and making up an "adapter" to mount the master cylinder in the stock location and not have to mount it under the windshield. I haven't changed the pedal ratio yet as I want to give it a try as it is first. The power assist was really giving me issues when I was staging the car. It didn't seem to bother Doug though. Hmmm.
This^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
wound up being a major PITA to make right. Removing the booster made the car difficult to stage even for Doug so I've spent the last couple of days "re-engineering" the stock pedal assy. The OEM assy. is quite complicated so I went to my favorite place (junkyard) and got another Cavalier assy. and an 80s Camaro assy. and "blended" the two together. I now have a 6-1 pedal ratio (OEM was between 3+ 4-1) and a nice feeling brake pedal.
My plans for this week are to build a couple of different collectors and see if I can make the header work a bit better.
Billy Nees 1188 STK, SS
Old 03-21-2021, 08:59 AM   #192
Doug Hoven
Liked 867 Times in 165 Posts
Here are some pictures Billy sent me to upload on here.
Name:	Me Tuning.JPG
ID:	57067   Click image for larger version
Name:	Cavalier Collector.JPG
Old 03-21-2021, 09:02 AM   #193
Billy Nees
Hey all you Mopar guys! Check out the Neon (with chute) that was stalking us all day.
Old 03-21-2021, 11:46 AM   #194
Billy, You should have just ordered those brake parts @ Summit or Jegs
Old 04-10-2021, 01:11 PM   #195
lvd2340
lvd2340's Avatar
Liked 4 Times in 2 Posts
Send a message via AIM to lvd2340 Send a message via Yahoo to lvd2340
What front tires are those? Are they Circuit Racing Slicks?
Billy Kirpens Jr / Pro ET / Street ET 123J @ Lebanon Valley Dragway
Stock/Super Stock 123A
lvd2340 is offline   Reply With Quote
Old 04-11-2021, 07:30 AM   #196
Billy Nees
I would guess that they are some sort of an asphalt "circuit" slick. Hoosier 19.5x7-13.
Old 04-11-2021, 09:53 AM   #197
Billy Nees
Well, in the openness of "fair-and-honest" reporting I guess that I should mention our last outing at Cecil. I don't really WANT to as it wasn't a banner day but I guess that it could have been worse. I at least learned some stuff.
The brakes worked out great! Doug could hold the car at 3 grand if he wanted to.
I built 2 different collectors for the car. The original one was 2 3/4" dia and about 15" long. I built one 2 1/4" and 15" and a second 2" and 24" planning on cutting it down.
I don't have my timeslips and notes with me but we made 7 runs all between a 15.25 and 15.28. Not too bad for changing things between runs. It wasn't a very good day, low baro., high humidity and head wind but at least the sun was shining. As I changed the collectors, we started to see a pattern develop. It went it's best MPH (by 1 full MPH!) with the 2" collector cut to about 10" long but it went it's best ET (15.25) with the original collector.
This past week, I was able to find some specs on the original cams and although they're both very small, the exhaust cam is really small. I'm starting to think that the restriction that is cast into the original exhaust manifold is there for a reason (duh, gee do ya think?). At any rate, Comp DOES make a "streetable" cam set that is a bunch bigger than the original ones and is under my .430 lift limit. I guess that I've got to buy some cams.
Old 04-11-2021, 11:14 AM   #198
Stan Weiss
Stan Weiss's Avatar
Liked 734 Times in 385 Posts
Billy,
Since it is DOHC. Have you thought about playing with the phasing of each cam before you try new cams? Unlike a single cam setup you can change LSA / overlap.
Stan
Old 04-11-2021, 12:13 PM   #199
Billy Nees
Yes, I have and the exhaust lobe is seriously retarded. If there wasn't anything commercially available, I would have "played" with moving the existing cam c/ls around. It does need (at least) a larger exhaust lobe.
Old 04-11-2021, 02:01 PM   #200
Stan Weiss
Stan Weiss's Avatar
Billy,
Thanks. Maybe I have confused this with one of your other threads. I was thinking this was as low a $$$$$'s build as possible.
Stan
