Old 09-16-2024, 08:36 AM   #1
Mike Savelle
Liked 7 Times in 5 Posts
Default sbc rear intake manifold oil leaks
whats the best to seal the intake ? I've been using red silicone for years , but the last two engines have leaked badly , I Even redid it and it still leaked, is the red silicone no good ?
Mike Savelle is offline   Reply With Quote
Old 09-16-2024, 09:58 AM   #2
JP1738
JP1738's Avatar
Liked 1,185 Times in 337 Posts
Default Re: sbc rear intake manifold oil leaks
I was having this issue on my super gas sbc. I used black gasket maker (Permatex) and smeared it liberally across the back of the china wall after a thorough cleaning. Hasn't leaked since.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old 09-16-2024, 10:00 AM   #3
JP1738
JP1738's Avatar
Well at least it doesn't leak out of the back of the manifold anymore. The engine leaks like a sieve, just not from there lol.
Dawson Pauley
Old 09-16-2024, 10:28 AM   #4
cad
cad's Avatar
Liked 91 Times in 51 Posts
Ford TA-31 RTV silicone. Ive used it for years.
https://www.amazon.com/Genuine-Ford-TA-31-Silicone-Sealant
Old 09-16-2024, 11:05 AM   #5
Mark Ugrich
Liked 71 Times in 38 Posts
G.M. 10-2006 engine sealant is good stuff also.
Old 09-16-2024, 11:50 AM   #6
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: sbc rear intake manifold oil leaks
Good morning to all,
I've been using the Permatex " Right Stuff " for a couple of years now.
The engine in my Suburban I recently went over the valve adjustment and found a couple of wet area's on the valve cover gaskets - I cleaned and used the Right Stuff on them and that oil leak is solved. No more oil smell while sitting in traffic. I use that on all my small block and big block china walls - zero leaks. It dries quick enough while dyno testing as well. I also use the Permatex Grey silicone with great success as long as you have time for it to properly cure. Make sure the surfaces are CLEAN and OIL FREE.
I found that to be very important in the curing process.
I hope that helps.
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
