Old 06-21-2024, 10:42 AM   #11
curtis reed
Liked 125 Times in 59 Posts
Default Re: Opening a can of worms
I have to wear -5 stuff in my roadster and I use this. If you want an advantage over your competition then consider it. I will sit suited up in my car in the sun and not be sweating with this.
I put a couple handfuls of ice and 3 4x6 frozen ice paks in the bag before each round. That will last about 10 minutes on the hottest days and will be cold enough that when you first start using one it's almost distracts you from the cold.
https://coolshirt.com/product/active-aqua-vest-2/
https://coolshirt.com/product/mobilecool12v/
Add whatever length hook up lines you need. At the end of the day I am so much less tired than before I started using it that it's surprising. I also us the AC in my trailer but just to cool down every so often so I can socialize between rounds. I have made up to 13 passes in a day at double races many times and it makes a huge difference. Stay safe guys.
curtis reed is offline   Reply With Quote
Old 06-22-2024, 12:35 AM   #12
Chad Fergen
Liked 24 Times in 12 Posts
Originally Posted by Ron Ortiz View Post
No matter how hot it gets, you need to sit down in the shade and take off your footwear and socks, it will help like you wouldn't believe.
Interesting. Thanks!
Chad Fergen is offline   Reply With Quote
Old 06-22-2024, 12:52 AM   #13
Chad Fergen
Thanks everyone! Great info.
