Old 04-07-2024, 11:47 AM   #11
Jason Shepard
Jason Shepard's Avatar
Liked 114 Times in 29 Posts
Default Re: Randy Mans DQ?
Originally Posted by MoJo Risen View Post
I'm shocked that the reduction of tech in stock has lead to these major rule infringements. Guess we won't see this car race for 10,000 at Indy this year. Congratulations. Replacing a steel roof with carbon fiber/plastic?
This is what Stock eliminator has become?
This car isnt "allowed" in the 10k race per the rules stated for that race.
Jason Shepard is offline   Reply With Quote
Old 04-07-2024, 11:52 AM   #12
Angelo DiTocco
Angelo DiTocco's Avatar
Liked 189 Times in 48 Posts
The roof panels on this generation hard-top (1994-2002) Firebirds and Camaros are plastic / fiberglass from the factory and are glued on with an adhesive - they are not steel and never were - be careful with the assumptions..... They are also not easy to replace.
That can happen to anybody, can we just hope that the guy's car is ok?
I don't know if any aftermarket companies are making a repro but I do know they are not available from the factory nor have they been for a very long time. I tried finding one a few years ago and had no luck. The only option is to get one from a donor car and to get it off you have to use fishing line or piano wire, work it under the panel, and slice through the adhesive. It can't be peeled off with a putty knife.
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
Angelo DiTocco is offline   Reply With Quote
Old 04-07-2024, 12:31 PM   #13
SSDiv6
I don't know if any aftermarket companies are making a repro but I do now they are not available from the factory nor have they been for a very long time. I tried finding one a few years ago and had no luck. The only option is to get one from a donor car and to get it off you have to use fishing line or piano wire, work it under the panel, and slice through the adhesive. It can't be peeled off with a putty knife.
Angelo is correct.
Depending on the year, both the roof and sail panels are either thermoplastic or fiberglass and GM discontinued them years ago.
When you go to the wrecking yard and try to remove them, it is worse than removing a windshield and they warp or get damaged. The OEM factory pieces were also defective and would bubble due to an issue with the epoxy and materials.
The aftermarket replacements for both the roof and sail panels are either fiberglass or carbon fiber.
Old 04-07-2024, 12:33 PM   #14
Bernie Cunningham
Liked 52 Times in 17 Posts
Angelo, I have a brand new one in the box along with all the components to switch from T-tops to solid roof.
Bernie Cunningham 7053 STK
Bernie Cunningham is offline   Reply With Quote
Old 04-07-2024, 12:39 PM   #15
Lenny5160_v2
Lenny5160_v2's Avatar
Liked 226 Times in 97 Posts
Aside from the fact that this car wouldn’t be allowed in the Indy $10k race, they are planning to have this car on track next week in Vegas.
Tony Leonard
S/ST 56
S/C 53
Lenny5160_v2 is offline   Reply With Quote
Old 04-07-2024, 12:45 PM   #16
Angelo DiTocco
Load it up Bernie !
PM message me with your number and I'll give you a call
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
Old 04-07-2024, 01:03 PM   #17
MoJo Risen
Liked 148 Times in 54 Posts
Originally Posted by Scott Dugdale View Post
Rumor on the street, only a certain group of folks can play in the sand box for the $10,000. Shake $ Bake, I might be rooting for some kind of Ford at the race.
TiPpY!!
If Robin Lawrence puts his car in the street version of 2013, just a switch of intake manifold, you'll see how dangerous a Naturally aspirated Coyote engine can be.
MoJo Risen is offline   Reply With Quote
Old 04-07-2024, 01:12 PM   #18
MoJo Risen
Angelo is correct.
It's good to know NHRA Tech officials are still getting technical facts wrong. Consistency is good.
Old 04-07-2024, 01:24 PM   #19
Scott Dugdale
Liked 57 Times in 20 Posts
Sounds Good, always like watching more cars with a clutch pedal. Last time I checked the stats there is quite a few in the Midwest.
Not sure I seen a carburetor from the factory in 2013...
Scott Dugdale is offline   Reply With Quote
Old 04-07-2024, 01:28 PM   #20
James Perrone
Liked 1,859 Times in 433 Posts
Thanks Angelo I thought the roofs were steel
Why the dq
james perrone 1290 STK
