Old 12-09-2022, 04:43 PM   #11
herbjr
Liked 83 Times in 32 Posts
Default Re: GT Rulebook Amendments
Originally Posted by CMcAllister View Post
Combinations where a simple carb/intake change changes the year of the engine?
'68 - '71 or even '73 Darts/Dusters with 340s?
Or is a different year spec engine all that is required to go to GT?
a 68-71 340 is a totally different engine from a 72-73 340, they can run GT
if a 69 engine is in a 72 car
herbjr is offline   Reply With Quote
Old 12-10-2022, 06:19 PM   #12
Ed McLawhorn Jr.
Liked 19 Times in 17 Posts
Originally Posted by Tom Meyer View Post
NHRA just took 283-237 down to 230 This stick cars in a Chevy II only Autos is 233. Chevelle with a stick is still 227, Auto is 217. SS/J K L M is a 1# weight break, where do the GT classes go 1/2# breaks? Tom
Tom, I believe GT/A starts at 6.00 and go 1/2 break all way to GT/Q at 14.00. 6th
Ed McLawhorn Jr. is offline   Reply With Quote
Old 12-11-2022, 12:21 AM   #13
CMcAllister
Liked 921 Times in 260 Posts
Correct. The 68-71s used different carbs on the same basic engine (mostly). My question was, will a simple carb change to something other than was used in the model year of car, i.e. a 68 Dart with a Thermoquad, make it acceptable for GT. I believe I got my answer.
Thanks.
Old 12-11-2022, 06:04 AM   #14
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Thanks.
71 340 should be legal in a 68-70 for GT.
Old 12-11-2022, 10:05 AM   #15
1347
1347's Avatar
Liked 1,026 Times in 281 Posts
Thanks.
Looks more than a carb change. A quick glance shows different compression ratios. Of course you could run less compression if its just a head gasket and chamber, But if its a piston cc, then that might be a problem.
Duane Hoven
1342 SS/GT
1347 is online now   Reply With Quote
Old 12-11-2022, 10:17 AM   #16
Mike Volkman
Liked 513 Times in 53 Posts
Need to watch Lonnie's post on NHRA with coverage of the PRI show - day 1 @ 9:00 am. Makes interesting point that they realize people will be switching back and forth to "hide" from competitors with specific engine families and made the statement that they "may" find themselves staying in GT for the year. How that comes about who will know.
Mike Volkman is offline   Reply With Quote
Old 12-11-2022, 01:00 PM   #17
Bryan Worner
Liked 535 Times in 86 Posts
Is NHRA going to start to be like other organizations and make fly by night rule changes? maybe if they would open up the quotas in stock and super stock and let more cars in they would get more heads up runs. People should just race their own car and worry about the rules that pertain to their car instead of crying to tech that others have an unfair advantage because they can run more than one class.
Bryan Worner is offline   Reply With Quote
Old 12-11-2022, 01:26 PM   #18
Paul Precht
68-71 have the same piston, deck height, valve size and head CCs.
Old 12-11-2022, 02:50 PM   #19
Byron Worner
Liked 37 Times in 7 Posts
I wonder if they are singling out GT with enforcement of rules or will they enforce all class rules in Super Stock Eliminator???
For example a Modified car that is required to run 2 carbs for a specific class but is only using one. Will this still be allowed or will it be corrected???
Byron Worner is offline   Reply With Quote
Old 12-11-2022, 03:58 PM   #20
james schaechter
I think it says a maximum 2 carbs or 3 2bbls in modified. Heck they didn’t really care too much when a well known modified racer raced in a heads up with more carb than allowed a few years ago so I doubt if they will change this.
I think if they did raise the quota just enough to be above the fields instead of defaulting to all run. Too much ladder playing because there is no fear of not qualifying. Why not make the minimum field 64 and let 80 in ? Or if they want a lower quota, make the field smaller, I realize some say that it isn’t fair etc. I would put it this way. Don’t sign up for a National event if you don’t want to try and actually qualify. There are many points meets to race in. There are some that are full fields plus and that means some don’t get in. We all seem to be able to survive when that happens.
I think also they should consider something such as more points for a heads up win and or more points for better qualifying or a record. Just little nuances that would drive racers to performance.
Maybe the SS category indexes should be lowered to reduce the number of stockers that can easily cross over with no mods and easily qualify for the SS field. If we care about SS vs GT, why not look at the easy path to SS by many stockers. Seems odd to push the GT SS deal without looking at that.
The GT rule change just reduces the places to hide. Not for all, for some.
I realize we can’t afford it to become comp. Heck comp racers can’t afford comp, so it has to be a balance. I feel like NHRA has been in support of policies that don’t require them to do the job that truly defines their existence. Anytime you have rules, you need teams to follow up. NHRA has no succession or sustainability plan for their tech dept.
The masters level tech personnel are aging out and retiring. If they don’t make some effort to help that, they will not be relevant.
James Schaechter 3163 STK
