Old 05-30-2022, 09:26 AM   #11
DCox
Liked 4 Times in 2 Posts
Default Re: 7000 Onan gas generator help
Originally Posted by John Duzac View Post
Had issuers with my 7000 Onan gas generator at Ennis double. Weather was way too hot and I am wondering if the high temps was some of the issues. The generator seemed to be working fine and for some unknown reason the generator would just shut off. I was then able to restart it and everything would work fine for a while. Five minutes later the same thing, only thing when the generator would start, there would have no electricity to charge the batteries of anything else. I would turn the circuit breakers on the generator and everything seemed ok with the two breakers. This went on for quite some time. Does anyone had issues like this? Thanks and help will be appreciated.
We just open side door and run a fan on it.
DCox is offline   Reply With Quote
Old 05-30-2022, 10:13 AM   #12
voltdr
Liked 100 Times in 51 Posts
What Rich said. I always put a fan to blow the hot exhaust away from the air intake, even in cooler weather.
Dan
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
Old 07-11-2022, 06:37 PM   #13
flash
Liked 6 Times in 5 Posts
is it as simple to just run a flexable tube down to the onan intake pipe and run it up to better air on front or side of onan gen to get better air than the super heated air under gen set. there is a Ibeam seperating intake and exhaust , but it is extremly hot under the trailer
flash is offline   Reply With Quote
