Liked 20 Times in 15 Posts
I have HF AC welder. it splatters. does the DC welder do more or less?
thanks Rod in AZ |
Liked 136 Times in 49 Posts
Is it a wire feed? Solid wire or Flux core? or Stick welder?
it is an AC flux core wire feed. welds good for what I do. just lots of berries
in corners or tight areas. Rod |
There are better grades of flux core wire..Hint: Don't use the stuff that comes with it.
Liked 378 Times in 143 Posts
I am far from an expert but I know on mine (Century welder) using flux core I always get a good amount of splatter. Same welder using gas is much cleaner. I never did try different brands of wire.
I have a Century (Lincoln) Flux Mig.
Like Mark said, the amount of splatter depends on the brand of the wire. I only use Forney and Lincoln and the amount of splatter is minimum. |
Liked 63 Times in 2 Posts
I have used anti splatter spray helps a lot to clean splatter off ...plus smells like frying fish when welding...lol
