#11 |
Liked 167 Times in 81 Posts
I think most stud breakage is due to inadequate clamping force .ie lug torque.. Plenty of fast cars on 1/2" studs for years.
Tim Schmackpfeffer 762 SS |
#12 |
Liked 1,144 Times in 354 Posts
Well between Larry and my Brother Bob and the stories, looks like I will go with 5/8". Looks like plenty of meat on the wheel to drill out for Lug Nuts.,
#13 |
Liked 27 Times in 14 Posts
If you DO drill the wheels, wait til you get the studs. Now you are potentially looking at drilling and taping the axles,and front hubs also. On top of that, I am not aware of any sleeves made to go around the stud to sit between the wheel and stud. Just the larger nut and exterior washer. Most of the wheels I have had my hands on slip right over the "5/8" stud fairly tight tolerance. only had one a tad sloppy. Then just a half inch spacer and torque em at 85.
#14 |
Strange lists 130lb. for torque. Even my 1/2" fronts go 90lbs.
#15 |
Liked 56 Times in 29 Posts
I bent a set of 1/2" grade 8 on a mid to high 11 sec. car. I use steel wheels with aluminum drums (they might squirm more than steel or iron drums; don't know) and now run grade 8 bolts in 5/8". I don't torque over 120 ft lb with lubed threads; check what torque your wheels can stand.
#16 |
Liked 8,231 Times in 1,540 Posts
#17 | |
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
